Results 1 to 15 of 15
    Nov 2019
    Sydney AU
    New Aussie here.
    Hi fellow enthusiasts, Justin here from Sydney Australia, long time lurker, owner of a 151 bulls bay, made by pioneer boats. Skiff essentially 6 degree dead rise, used to run a 50 Tohatsu, sold that fitted a 70 yammie, 2005 two stroke, any way, just thought I’d say hello.
  2. Likes tnelsmn, whipper liked this post
    Jul 2005
    AZ
    '84 Checkmate Convincor
    Pekin, IL
    Welcome to the site. All kinds of different here. Even some of the boats.
    Rock
    Team Junk
    Jul 2005
    AZ
    So what kind of speeds are you getting out of your rig?
    And any pics?
    Nov 2019
    Sydney AU
    Trimmed up, one person not running tidal, 41-2 mph, since then slowly losing top end, reed valves are going to be replaced soon, with bigger carbs off the 90hp. Photos soon.
    Nov 2019
    Sydney AU
ID:	452375Click image for larger version.
ID:	452376Click image for larger version.
ID:	452377Click image for larger version.
    Quote Originally Posted by Pjpoppet View Post
  8. Likes tnelsmn, mrichartz liked this post
    Sep 2017
    Ashland city tn
    Welcome to the jungle (s&f) Slowly losing wot rpm usually ain't reeds. Gonna need do sum compression or leak down to c what u got. R u runnin good temps?
    Only other thing I could think b is boat takin on water adding weight (water logged) ?
  10. Thanks Pjpoppet thanked for this post
    Nov 2019
    Sydney AU
    I am a automotive mechanic, compression test done although on the low side, 115,110, 105, battery was a little flat too, it pops out if the lowest carb, also hard starting, have checked spark, reset timing, static and with light, bilge is dry mainly, I am a bit of a tinkerer, so I usually just check and replace things so I know they are spot on.
    Sep 2017
    Ashland city tn
    Completely understand. I'm just a tinker also. Really enjoy playin (building) these ole mercs. I know u have the yammi but I think compression is inline with the mercs @ around 120ish for a healthy motor leak down will tell better. that 105 cyl may have high leak down #s but idk may not usually if I'm loosing wot rpm or speed I'd look at spark or cyl health possibly carb gunked up. The bottom carb that's spitting? Is that the 105 cyl?
    Nov 2019
    Sydney AU
    Not losing rpm, just running out of puff, I might try the 17 pitch again and get her up to 5900 again, although when the 18 pitch went on I could still turn 5600-5700 and hit the low 40s, the 17 would run out at 38ish. Yes temps are spot on.
  14. #11
    Sep 2017
    Ashland city tn
    If u losing mph ,rpm goes along with it. If u gotta drop pitch on prop to get same rpm as other prop. ur losing power
  15. Thanks Pjpoppet thanked for this post
  16. #12
    Nov 2019
    Sydney AU
    Makes total sense, thanks.
    Pekin, IL
    Try Chris Carson for the reeds. Sounds like you need them.
    Rock
    Team Junk
  18. #14
    Nov 2019
    Sydney AU
    Quote Originally Posted by rock View Post
    Rock
    Just ordered a set, thanks.
  19. #15
    Oct 2005
    savannah,ga
    Welcome aboard! Bulls Bay boats are built an hour away from my home. Good boats built by people who stand behind their work.
  20. Likes Pjpoppet liked this post
  1. Aussie Missile
    By AZMIDLYF in forum Photos and Videos
    Last Post: 11-15-2018, 11:06 AM
  2. Practice 1 for the Aussie GP
    By Capt.Insane-o in forum General Boating Discussion
    Last Post: 03-14-2013, 09:02 PM
  3. Aussie Aussie Aussie Ken Warby the fasted man on water still 33 years later
    By SUPER STRANGLER in forum International Performance Boaters
    Last Post: 06-09-2011, 04:21 AM
  4. Aussie sst100
    By Bullshot in forum General Boating Discussion
    Last Post: 04-29-2011, 07:24 AM
  5. Aussie Merc fan , new guy!
    By shortshaftred100 in forum Outboard and Racing History
    Last Post: 11-26-2007, 07:48 AM
