Page 2 of 2 FirstFirst 1 2
Results 16 to 24 of 24
    Mar 2009
    Lake Vermilion, MN
    Grant, I have a 22p 4 blade, basically new, I believe is the Scorpion or L4, $275, its I'm near Forest Lake, MN you could try it out before buying!
  2. #17
    May 2013
    Owasso, OK
    They make a 22. I have one brand new in my garage I need to test. If it doesn’t work out I’ll post here. Ran a 23, felt it was closer to a 26 than 25.
  3. #18
    Mar 2003
    Belvidere IL, FARM
    What do you mean when you say it runs "stiff"?
    God, Country, and Fast Boats
  4. #19
    Jul 2004
    Connecticut
    Quote Originally Posted by lance View Post
    I recently ordered a new 23". The new models come with the Solas variable vent holes with adjustable rotating disks. The old models have small locating vent holes that can be drilled for additional venting.
    I did not know that the Solas Scorpion's now only come with the variable PVS disks. Have you run it yet to see how they work?
  5. #20
    Jun 2002
    Northern Utah
    It will be several weeks before I can try it. My boat needs a lot of venting. I run all 8 PVS holes open on my Bravo. I doubt the variable venting will be enough on the Scorpion. I'll be removing the rotating disks and open up the hole just a bit more but still keep the disk mount threaded hole.
  6. Thanks Greg G thanked for this post
  7. #21
    May 2013
    Owasso, OK
    Quote Originally Posted by specboatops View Post
    The scorpion seems to run 2.5-2.75 pitches high. I tried a 23, couldn’t twist it as hard as my 25 Tempest.
  8. Thanks specboatops thanked for this post
  9. #22
    Jul 2004
    Connecticut
    How did you end up with the new style Scorp?
  10. #23
    Jun 2002
    Northern Utah
    I ordered the Scorpion from Overtons in Jan. I believe it was shipped directly from Solas (not sure), but it did take several weeks to get it.
    As I expected, the variable venting isn't even close to being enough for my setup. I tried just removing the tunable disk and then finally die grinding the entire variable vent part away so all that was left were 3, 1" holes. This is still not enough. On hole shot it spins to about 2800 and slowly comes out of the water. I need about 4500 for a good holeshot.
    I still haven't rung it out for top end. I don't get out enough and there has been a ton of boats out especially wake and surf boats. The 23" runs about about 50mph @ 4000 at part throttle so for a 23" it is very stiff. When get some good top end numbers I may send it off to get a set of PVS holes added to the 1" holes.
  11. Thanks Greg G thanked for this post
  12. #24
    Jul 2004
    Connecticut
    Thanks for the info. It looks like they have added 21 and 22 pitch sizes recently.
  1. 27P Solas Scorpion
    By Mklock in forum Propellers
    Last Post: 06-26-2019, 01:03 PM
  2. WTB Solas Scorpion 25
    By Wolfjr in forum Propellers Wanted
    Last Post: 02-10-2019, 07:23 PM
  3. 24" Solas Rubex L4 -- Bravo I Copy
    By lance in forum Propellers
    Last Post: 02-28-2017, 10:38 AM
  4. Solas rubex l4 prop
    By WillySteve in forum General Boating Discussion
    Last Post: 08-14-2016, 06:41 PM
  5. Solas Scorpion
    By Walleyehed in forum Props, Setup, and Rigging
    Last Post: 05-27-2016, 02:53 PM
