Page 2 of 2 FirstFirst 1 2
Results 16 to 28 of 28
    Aug 2016
    Minnesota
    Thanks for looking... Its really driving me nuts.
    Starting to wonder if it isnt for a mercury and that's the problem but wouldn't I have issues with the splines then? It slides on perfectly so with the right washer it should work fine.
    I will try a local prop shop today and just see what they say.
    1995 ProCraft SuperPro 180 / Mercury 150 XRI
  2. #17
    Jul 2002
    Las Vegas, NV
    Let me know if you figure out what you need...I can look a bit.
ID:	452566   Click image for larger version.
ID:	452567   Click image for larger version.
    Keith-
  3. Likes mrichartz, Robby321 liked this post
  4. #18
    Dec 2001
    Looks like wampum.
  5. #19
    Aug 2016
    Minnesota
    The two circled ones look right are they the same? If you can look at the image I posted it is going on a 2.5l merc and is an old trophy prop
ID:	452615Click image for larger version.
  6. #20
    Dec 2017
    New Smyrna Beach FL
    Quote Originally Posted by gguertin145 View Post
    Those look like my Yamaha washers
    I've bought and sold 23 boats in 27 years. I fix them up and then get bored and look for another. It's a hobby.
    Liberator SOLD. Looking for a new project....
  7. #21
    Sorry I just got down to the shop. 12-835467-1 is the proper thrust washer which is what it looks like you have. It does not sit down in the prop against the hub. Just on the flange.
  8. #22
  9. #23
    Jul 2002
    Las Vegas, NV
    The washer in the 2nd pic definitely isn't correct. Here's what it looks like.
ID:	452676   Click image for larger version.
    Keith-
  10. #24
    The washer in your second pic is for a Yamaha.
  11. #25
    Aug 2016
    Minnesota
    Ok so vnemous just to make sure I understand your saying its ok that the washer does not sit inside the recessed portion of the prop and rests on the outside of it?Click image for larger version.
  12. #26
    May 2001
    Ga
    That's correct ,just install a standard merc washer. A step washer is not used . hf...
  13. #27
    Aug 2016
    Minnesota
    Quote Originally Posted by half fast View Post
    Thanks!
  14. #28
    Yes Now you got it
  1. Prop thrust washer
    By Onetime in forum Technical Discussion
    Last Post: 10-25-2014, 06:09 AM
  2. Thrust washer for SRX prop?
    By XstreamVking in forum Props, Setup, and Rigging
    Last Post: 03-31-2014, 04:26 PM
  3. Prop thrust washer
    By Burke Kilgour in forum Technical Discussion
    Last Post: 06-10-2004, 08:59 PM
Eddie Marine - Horizontal
