Page 2 of 2 FirstFirst 1 2
Results 16 to 21 of 21
    Sep 2019
    Lake Keowee, SC
    Engineermike is correct. In addition to the housing diameter, the Torque Master cannot be raised nearly as high as the Speedmaster because it still has the lower 3 holes on the side of the gear case, plus additional lower holes on the housing. The Speedmaster has all the water intake holes on the bottom of the housing leading edge nose. However my boat would likely slow down if I had the Speedmaster and I am only running 72 - 75 mph.
  2. #17
    Oct 2009
    Gonzales, La
    Quote Originally Posted by mjw930 View Post
    Is there a new TM case or was the SM and HD 5.44" the only cases brought over from the 400R?
    I don’t know for sure but on the website it looks like the same ole torque master. I wouldn’t want to try to drag the entirety of a 5.44 non-surfacing case through the water at 70+ though.
  3. #18
    May 2009
    Ormond Beach, Florida
    Quote Originally Posted by engineermike View Post
    Agreed, it looks like the older case. I’d agree on prop selection, if it’s the same lower then something that worked on a 300XS TM should work fine on a 300R TM.
    Mark
  4. #19
    Oct 2009
    Gonzales, La
    I’m thinking it might be worth trying a pro max prop. That was the fastest 4-blade I tried and acceleration was good too. The blades are shaped similar to the blaster but it’s through-hub.
  5. #20
    Sep 2019
    Lake Keowee, SC
    The Promax is certainly one of a few I want to try. I need to try props that I can raise the jack plate without excessive slippage. Mercury says 3" to 3.5" below for the TM lower unit. I believe my 300R TM is the same TM that was installed on the 2 stroke 300XS in the last couple of years. On many bass boat forums I see that most have them set up around 3" below but a few guys have them set up at 1.5" to 2" below. Of course with the hull they have they are using around 20" - 24" of set back and I have 10" of set back. So that might be one reason they can raise the TM that high and maintain water pressure. I feel confident the ProMax would hold 2" below the hull whereas the Bravo FS will not. I would even consider trying a Max 5TS but I think the TM will run out of water pressure around 2" to 2.5" under on my boat and if it did, the 5 blade will probably have too much drag.
  6. #21
    Oct 2009
    Gonzales, La
    I actually am running a max5 ST now. Not everyone realizes the ST is also 1/4” larger diameter than the earlier max5.
  1. 21 Liberator. 300R with 34 CNC prop, 112 MPH!!!
    By WILDMAN in forum General Boating Discussion
    Last Post: 01-02-2019, 09:34 AM
  2. Prop Selection??
    By stratos92 in forum Props, Setup, and Rigging
    Last Post: 06-24-2011, 06:56 AM
  3. Prop selection
    By fisher200 in forum Props, Setup, and Rigging
    Last Post: 07-09-2008, 10:38 AM
  4. prop selection for a voo-doo with 60 omc? help please
    By voodoorye in forum Technical Discussion
    Last Post: 02-06-2008, 11:41 PM
