Results 1 to 12 of 12
    Nov 2005
    NE Alabama - Weiss Lake
    Eliminate Chine Walk?
    Title says it all except "how to". My rig is much smaller and slower than most here so hopefully my chine walk will be easier to get rid of. My boat is a 13' Speedster with a stock late model 60hp Merc 4 stroke. I'm currently running an aluminum 15" prop and have a 20" SS cleaver ready once I get the handling down. I have trim tabs. The boat may be stern heavy. At 35 it gets a bit squirelly and at 40 its a handful. I should be hitting 60 but no way until I figure out how to beat the chine walk.
    Thanks in advance TJ
    TJ309
    Older 17 foot Laser / 2.5L Merc 245 Racer
    1993 Speedster 13 / 2019 Merc 60 play boat
    2020 Lowe 24' Pontoon boat / 250hp Merc. 51mph!
    72 Hydrodyne bubbledeck undergoing keel up restoration
    2 Jetski's
    Sep 2017
    Ashland city tn
    Gonna need more Info on set up. prop shaft height? Jackplate? Low water pickup? Does boat have a pad?
  3. Likes nitro_rat liked this post
    Jul 2012
    Lufkin, Texas
    Quote Originally Posted by Merc 2.5 View Post
    Also what kind of steering?
    Jul 2015
    NC/TN/KY
    On some faster boats you have to just drive through it. Once you do it a time or two you can minimize it by how you drive the boat. Setup is key like the prior posters have asked for info on. Best of luck figuring it out. You will.
  6. Likes Euroski liked this post
    Lake Coochiching, Ontario
    Raising the engine helps. It helped on my first V bottom, a 13' Voodoo with a 70 Nissan. Other things that have helped my boats: foot throttle, 4 blade props, smaller diameter props, lower pitch. But at the end of the day, most likely you will have to drive. The foot throttle is so you have two hands to steer. It's easier that way.
    You can start with gentle left turns and then countersteer as the boat falls to one side or the other. Small steering motions are better. My brother can drive his V bottom but his motions are too big for my Allison. I can drive his boat.
    Practice and be patient.
  8. Likes Jimboat, Baja170 liked this post
    Ontario, Canada
    Quote Originally Posted by tj309 View Post
    TJ - Try changing weight distribution, reduce fuel load for test and any improvement? Try changing engine height - this can cause onset of chine-walk.
    As David suggests, trying a higher motor setup is a good idea. Two reasons why it can help - 1) higher prop shaft generates less bow lift, less tendency to chine walk; 2) chine walk is a dynamic instability that is often resolved by changing dynamic balance of the hull (engine height is one of the actions that will accomplish this.)
    Here's an article on causes and fixes to chine-walk. or also here's some more suggestions for addressing chine walk in this article.
  10. Likes Baja170, TNRoostertail liked this post
  11. #7
    Dec 2001
    Tight steering.... mounts.... and the highest transom you can W/ out sucking air.... a cupped prop helps.... JMO. If used 4 stroke.... mounts could be lose...... 25 inch motor on 20 inch boat ?.... need more info.....
  12. Likes nitro_rat liked this post
  13. #8
    Jul 2012
    Lufkin, Texas
    I would do whatever it takes to get solid mounts in it. With a small hp late model 4 stroke that likely means custom mounts...
  14. #9
    Dec 2001
    HeeHee..... or a tube of 5200 in the rite places........ask me why.........semi solid mounts don't break things not to strong...........
  15. #10
    Sep 2017
    Knoxville, TN
    Dave we need more info, we need pics and .............. why??
    Respect no wake zones!!! Evinrude guys need a place to race too.
  16. #11
    Who would sell solid mounts for a 60 HP 4 stroke? Would the 60 race motor mounts fit?
    Dec 2001
    Red neck mounts.......on an old Merc I used to put a rock...... ya.... and fill in the rest with body puddy.... on the lowers... on mercs.....cut the top so it bottomed out sooner on the tops. You could fill in all the air space with 5200 it dries stronger than merc mounts..... JMO.....Look and think......what you can do to tighten it up.....As to the 60 4 stroke......I don't know.... I will look at one to see what could be done.... How worn are yours ?
  1. Chine walk
    By jeff wilson in forum Racer's Hangout
    Last Post: 07-06-2010, 09:19 AM
  2. chine walk
    By macutty in forum Props, Setup, and Rigging
    Last Post: 12-06-2007, 12:12 PM
  3. Got thru chine walk...now what?
    By tj309 in forum Technical Discussion
    Last Post: 08-22-2007, 01:57 AM
  4. chine walk (help)
    By captain chris in forum Technical Discussion
    Last Post: 06-27-2007, 11:16 PM
  5. Chine walk help
    By Lockjaw in forum Props, Setup, and Rigging
    Last Post: 06-26-2006, 04:08 PM
