Results 16 to 25 of 25
11-05-2019, 08:42 PM #166000 RPM
- Feb 2014
- Missouri
- 1,212
- 66
- 12
- 83
If you’re in break in by chance the 3.0 speed smoke and oil from bleeds and such like crazy
11-05-2019, 08:54 PM #175000 RPM
- Apr 2015
- Oceanside, NY
- 155
- 20
- 10
- 51
- 119
11-05-2019, 09:03 PM #186000 RPM
- Feb 2014
- Missouri
- 1,212
- 66
- 12
- 83
I don’t remember specificly if it dumps in to exhaust on 3.0
the gasket me and merc I think is the adapter gasket under the power head. Water and exhaust both flow through it.
11-06-2019, 11:54 AM #195000 RPM
- Apr 2015
- Oceanside, NY
- 155
- 20
- 10
- 51
- 119
11-07-2019, 01:42 AM #20
Does it get to operating temp on both banks?
11-07-2019, 12:04 PM #215000 RPM
- Apr 2015
- Oceanside, NY
- 155
- 20
- 10
- 51
- 119
11-07-2019, 12:16 PM #22Screaming And Flying!
- 14,753
- 381
- 1305
- 5602
- 11033
Blown crank seal?
11-07-2019, 12:23 PM #235000 RPM
- Apr 2015
- Oceanside, NY
- 155
- 20
- 10
- 51
- 119
11-07-2019, 12:59 PM #24
Ohm spec the air temp and head temp sensor? Those motors have to warm up at idle or they run snotty. And check the fuel pump for a torn diaphragm.
11-14-2019, 04:24 PM #25
Real early 3.0L had a tendency to crack the exhaust port on the adapter plate. The ones that don't crack will usually burn the gasket out between the ports.
You can run the motor without the lower unit on. You'll have to rig a water hose to the water tube and use a borescope camera with a long whip to look in the exhaust runners. The runners themselves should be dry, the areas around them and a bleed hole in between the ports should be moving water out.
http://parts.promarineusa.com/produc.../30/210/1060/1
The green 27-830 for the early model doesn't have previsions to cool between the ports, they learned their lesson and changed the adapter plate. The late-model 1998 to present uses the 27-831 which lasts a little longer ... but they burn out too ..
Capt.Insane-o liked this post
225 efi Sneeze and sludge
By Seanj85 in forum Technical DiscussionReplies: 20Last Post: 10-18-2019, 10:22 PM -
Stock 16 amps ( gray color) Merc v6 flywheel
By DonChicho in forum Parts WantedReplies: 2Last Post: 12-28-2017, 09:41 PM -
Sludge in my oil tank
By Cgriff in forum Technical DiscussionReplies: 2Last Post: 08-03-2015, 03:07 AM -
Mercury Tech: Sludge?
By P man in forum Technical DiscussionReplies: 9Last Post: 04-13-2009, 08:24 AM -
Why Brown Dust from near Seastar Pro on 2.5 Merc
By Lakebum in forum Technical DiscussionReplies: 6Last Post: 08-10-2005, 12:31 PM
