Results 61 to 67 of 67
Thread: 2.4 powerhead trnsplant question
11-27-2019, 04:58 PM #616000 RPM
- Feb 2011
- HUDSON, FLORIDA
- 1,530
- 433
- 64
- 435
- 452
11-30-2019, 08:29 AM #625000 RPM
- Feb 2013
- Northern Cal
- 190
- 18
- 37
12-03-2019, 10:11 AM #636000 RPM
- Feb 2011
- HUDSON, FLORIDA
- 1,530
- 433
- 64
- 435
- 452
12-06-2019, 05:14 PM #646000 RPM
- Feb 2011
- HUDSON, FLORIDA
- 1,530
- 433
- 64
- 435
- 452
my transplant has turned into a nightmare! ive got a real mess, problem is15'' tiller is slightly higher than 20'' clamp so when i swancwich the top plate it forces the 2pc plate up, leaving a gap,bottom plate to can . both plates / mounts fit nice together, but the 2 long tiller bolts wont slide thru the tighten alu. mounts. the whole 2pc assembly lifts off can. a double gasket wont be enough. thinking of boring out the thru bolt hole in the mounts,they need to drop down. i cant raise the can or lower the tiller. the plates sit about 1/8 too high. MAYBE turn the mounts on a lathe and 5200, to seat them in? the 15'' cut man must have been a little off..... I THINK i was off, itsall together, if i can get some help ill pull it out and put the hose and fire it up. 15'' was cut correctly. went together smooth, all lined up.
12-27-2019, 10:24 PM #656000 RPM
- Feb 2011
- HUDSON, FLORIDA
- 1,530
- 433
- 64
- 435
- 452
I ASSUMED the water pump was good, pumped fine but sitting for over a year. well of course, no water pressure. it would have been soooo ez. what was i thinkin??? now i have to wrench my painted lower, see whats up. didnt think how long it sat. the 2pc adaptor switch had me occupied.
12-28-2019, 04:57 PM #66
Hows she sound tho?
12-29-2019, 09:56 AM #676000 RPM
- Feb 2011
- HUDSON, FLORIDA
- 1,530
- 433
- 64
- 435
- 452
Good, better than my back feels, for sure.
Powerhead question
By lvnspeed in forum Technical DiscussionReplies: 7Last Post: 01-17-2008, 11:16 PM -
Merc V-6 powerhead question
By transomstand in forum Technical DiscussionReplies: 2Last Post: 01-10-2005, 07:58 PM -
Merc Powerhead question?
By optimax135 in forum Technical DiscussionReplies: 3Last Post: 08-12-2004, 06:59 AM -
OMC Powerhead question
By ROLF in forum Technical DiscussionReplies: 3Last Post: 09-30-2003, 12:08 AM -
Powerhead Question
By LaserLTV in forum Technical DiscussionReplies: 2Last Post: 09-28-2001, 09:04 PM
