Results 31 to 45 of 67
Thread: 2.4 powerhead trnsplant question
11-09-2019, 08:22 PM #316000 RPM
- Feb 2011
- HUDSON, FLORIDA
- 1,528
- 427
- 63
- 433
- 450
10-4 Ill pre-mix so far so good. thanks again.
11-09-2019, 08:44 PM #32
11-10-2019, 10:13 AM #336000 RPM
- Feb 2011
- HUDSON, FLORIDA
- 1,528
- 427
- 63
- 433
- 450
11-10-2019, 10:19 AM #34
18 3/4 length and roughly 9/16ths outer diameter
11-10-2019, 03:02 PM #35
I would change the oil gear on the crank if the injection is necessary. It's already on borrowed time. Good luck , those motors are strong.
Cheaters never Win !!!
11-10-2019, 04:26 PM #366000 RPM
- Feb 2011
- HUDSON, FLORIDA
- 1,528
- 427
- 63
- 433
- 450
your the man, thank you again. tom orrow gonna wheel it outside, putin some light pre-mix hook up my afro supply and harness, vice grips holding my \batt cables on. change the spin on, put the hose to my makeshift watertube and let her run. check stats. loose the oil pump...
11-10-2019, 04:43 PM #376000 RPM
- Feb 2011
- HUDSON, FLORIDA
- 1,528
- 427
- 63
- 433
- 450
yes, i mentioned a little slower than my $$$$$2.5 pm. but alot louder. ill just pre-mix like my other 150/ 225. hope i dont run into any frozen bolts on adaptor plates. have a bobs alien cowl, pan, skirt but like the old louvered mariner. ill shoot the 15 mid n lower silver gray, should be interesting look. old school, like me. im fired up!!!! without all the replys i wouldnt have made such progress, cant say enough.
Merc 2.5 thanked for this post
11-10-2019, 06:29 PM #38
I have a block off kit u welcome to if u need it and it will work. Just pay the ride
11-11-2019, 08:37 PM #396000 RPM
- Feb 2011
- HUDSON, FLORIDA
- 1,528
- 427
- 63
- 433
- 450
ILL pm you. today i found a nasty black oil puddle on the floor under the mid from running it yesterday. thought it was from tuner wit all the smoke. looked up in can, tuner was dirty but dry. area where driveshaft slips in wet, black oil coated? would that be the lower crankshaft seal? just guessing.why would it be so dark nasty like 20w50. is this something i can fix[seal] or is it major work? is pressure forcing the gunk out?
11-11-2019, 08:55 PM #40
What bout fuel pump diaphragm? It will flood #4 or 6. Cant member and run out on ground
11-12-2019, 10:34 AM #416000 RPM
- Feb 2011
- HUDSON, FLORIDA
- 1,528
- 427
- 63
- 433
- 450
11-12-2019, 05:19 PM #42
No biggie if crank seal. Just b careful workin round crank and dont scar it
11-13-2019, 09:50 AM #43
If the gunk is around where the driveshaft passes through its the seal. If it came out of the exhaust it wouldn't be in that area.
11-13-2019, 10:49 AM #446000 RPM
- Feb 2011
- HUDSON, FLORIDA
- 1,528
- 427
- 63
- 433
- 450
I agree. now, for my final question, will the 2.4 220 with its factory 2 pc adaptor bolt up to a ridgeback mid? its been cut to a15'', also is a ridgebk some special model of sorts? any ideas of years produced? is it a race piece? has single piston. will i be able to get a adaptor gasket?
11-14-2019, 07:42 AM #45
Not sure bout plate question on a 15in. I just dnt no. But the ridge back and smooth back. Racin/offshore. Ridge back has a squarish metal protruding down cent of the mid. Smooth back is just smooth. Hope that helps
Powerhead question
By lvnspeed in forum Technical DiscussionReplies: 7Last Post: 01-17-2008, 11:16 PM -
Merc V-6 powerhead question
By transomstand in forum Technical DiscussionReplies: 2Last Post: 01-10-2005, 07:58 PM -
Merc Powerhead question?
By optimax135 in forum Technical DiscussionReplies: 3Last Post: 08-12-2004, 06:59 AM -
OMC Powerhead question
By ROLF in forum Technical DiscussionReplies: 3Last Post: 09-30-2003, 12:08 AM -
Powerhead Question
By LaserLTV in forum Technical DiscussionReplies: 2Last Post: 09-28-2001, 09:04 PM
