Results 1 to 12 of 12
    Jan 2018
    Alabama
    Boat Rotiisserie - How To Ideas Needed
    I've got a 16 foot boat that I want to flip for repairs and paint. I'm thinking about building some kind of rotisserie and would like help with ideas. I've got an old jack plate that I can use for the rear pivot attachment point and it will keep the chain back away from the rear sponsons. I'm not sure how to attach the front end/bow and be able to swivel without damage to the bow surface. The bow eye is a U shaped Stainless 3/8" one. Photos or drawings would be greatly appreciated. Gordon
ID:	451989Click image for larger version.
ID:	451990Click image for larger version.
    Pekin, IL
    Years back I built one using a steel plate that bolted to the transom with a piece of 2" pipe welded to it. The pipe fit inside a 2 1/2 pipe the was welded to a piece of large angle we bolted to the forks on a fork truck. Put a couple guys on the front and let the fork truck handle the weight. Once high enough we spun it around and set it down. This was on a fairly light Hydrostream and it worked well. I think it is still around the shop somewhere and if you have a way to use it you are welcome to it (if I can find it ). I have also seen guys use a chainfall hooked up in a tree and with a little manpower assistance got the job done. If you want me to search for that piece, let meknow.
    Rock
    Team Junk
    35 Post(s)
    Boat Roto-Jigs
    Quote Originally Posted by Gordon02 View Post
    2 Harbor Freight engine stands should work (without the wheels). Add wooden crib boxes under each stand to get hull beam width clearance from floor or driveway. Stern mount can be adapted with a couple layers of 3/4 plywood (transom engine holes) and a bow eye u-bolt welded to a piece of plate for the bow engine stand. An engine cherry picker should come in handy for lifting the hull.
    Jan 2018
    Alabama
    Thanks Guys!
    Jul 2015
    NC/TN/KY
    Cool project. GT150 right?
    Jan 2018
    Alabama
    Thanks, yes, 1971 GT150. I'm enjoying this one - so simple.
  7. Likes Baja170 liked this post
  9. Likes Baja170 liked this post
    Jan 2018
    Alabama
    Guys, Thanks for these inputs. This Nose Piece is brilliant - and what I needed to see. I was having a hard time with how to support the bow in a stationary height without slipping or jerking. This should allow the rotation in a smooth fashion. Great stuff in that video. Gordon
Name:	Nose Piece.JPG
  11. Likes noli, Baja170 liked this post
    Minneapolis MN
    Great set up Noli. Been starting to think of how I'm going to flip my project in the coming months. This looks like a great idea.
  13. Likes Baja170 liked this post
    Aug 2015
    Cass County Mo.
    Like this Rock?
    Southside, Al.
    Did something very similar to flip the skater. Two pipe's that fit into portable engine hoists from harbor freight. One bolted to the bow eye, other to a plate/swivel bolted to transom.
    Got the job done by myself. Won't try that again!
  16. Likes Baja170 liked this post
    Aug 2014
    West Bend, WI
    I just flipped my 16 foot avenger, I lifted the stern close to the center, the front I hung from a old section of dock. I think the lifting from the center is the key. Even with just having a chain hooked to the front eye, there was never a snap, just nice and slow. I did it by myself.
  1. '08 Opti 200 mod ideas needed
    By cglenn in forum Four Stroke and Direct Injected Two Stroke Engines
    Last Post: 01-24-2012, 01:17 PM
  2. mirage pics needed for paint ideas
    By bigbluechevy454 in forum General Boating Discussion
    Last Post: 09-22-2011, 08:15 PM
  3. help...ive got a bad hook, ideas needed
    By jerry1865 in forum Technical Discussion
    Last Post: 04-18-2009, 06:38 PM
  4. Ideas needed for rear seat redesign...
    By STV_Keith in forum General Boating Discussion
    Last Post: 02-23-2007, 02:43 PM
  5. Kit Boat Ideas
    By tinytim720 in forum General Boating Discussion
    Last Post: 07-24-2006, 12:19 PM
