Results 1 to 15 of 19
    Jun 2009
    Bristol, Connecticut
    93 Mercury cowl seal gasket
    It says the cowl seal weatherstripping gasket for the cowl is not available anymore NLA for the early to mid 90s Mercurys. What are you guys using as a replacement?
    Dec 2001
    What The Happens is a Cowl seal gasket ?......I have used what ever it is.......
    Jun 2009
    So are you saying I could rip my TORN one off and not use it? (It’s the rubber trim that is fixed on the bottom edge of the cowl so it seals against the lower cowl skirt)
    Dec 2001
    Are you talking about a stock fissing cowl or race style lift off?
    Mar 2015
    DFW
    If you search on Amazon it is sold on there.
    Jun 2009
    Stock offshore 2.5 fishing
    Jun 2009
    Quote Originally Posted by Noah Burns View Post
    Do you have a link? Because I couldnt find it
    Dec 2001
    have used......
    Jun 2009
    Bump looking for ideas because I need to replace the ripped gasket on my cowl before spring !!
    Mar 2004
    vonore tn.
    I have used 3/8 fuel or water hose to replace gasket in a pinch. Trick is get the softest [most flexible], you can find. Then glue it on with bellows adhesive.
    Jun 2009
    I was thinking of using something like this, which is the closest I could find to the stock gasket...the stock gasket alos has an o-ring inside of the trim. So I might need to also use some rubber cord inside the bulb trim weatherstripping
  12. #12
    Plainville, CT
    You ever get this settled?
  13. #13
    Jun 2009
    Quote Originally Posted by glastron1987 View Post
    you ever get this settled?
    nope
  14. #14
    Plainville, CT
    Best I've been able to find is to search ebay for "Push-on Weatherstrip Car Door Edge Seal". A lot of choices come up and you'd have to match something up. Probably that's about how you found the one you posted above. In any case I can generally find just about any Merc part online, but can't find that one.
  15. #15
    Plainville, CT
    You have dimensions and a photo of the OEM one?
