Results 1 to 2 of 2
    Sep 2017
    Miami
    Livorsi Jack plate gauge
    This is a like new in box oversize Livorsi jack plate gauge. It was test fit, but we changed plates and it was not compatible with it. Oversize (2"5/8) Platinum dial, black mega rim.
    $39.00 will ship.
    The Livorsi plate gauge is compatible with most brands, including Bob's, Hydrodynamics etc.
    From Livorsi website:
    Position Applications
    Rudder indication, trim indication, trim tab indication jack plate indication, jet pump bucket indication, throttle position, throttle percent, valve open/closed position, valve open/closed percent, etc.
    5VDC reference voltage supplied by gauge. No additional wiring needed.
    High and low adjustment pots for precise indication and fine tuning.
    Gauge cutout 2-5/8inch with water resistant plug in Duetch connectors.
    Custom harnesses available upon request.
    Pressure/Vacuum Applications
    PSI, PSIA, PSIG, PSID, Vacuum
    Works with all 1-5 VDC senders.
    270 degree sweep for precise indication. High and low range adjustment pots and fine tuning.
    Custom harnesses available on request.
    *Compatible with most major jack plate manufacturers including Bobs Machine Shop and Hydro Dynamics
    Sep 2017
    Miami
    Price drop to $39
  1. Nordskog gauge for CMC jack plate quit
    By jmiller165 in forum Electronics, Audio Systems, and Wiring
    Last Post: 03-07-2014, 12:25 AM
  2. Jack Plate gauge
    By nik kurdziel in forum Technical Discussion
    Last Post: 07-19-2007, 11:50 AM
  3. Switch & Gauge for Jack plate
    By Sutphen20 in forum Props, Setup, and Rigging
    Last Post: 07-27-2005, 12:20 PM
  4. Jack Plate Gauge
    By ShoreThang in forum Technical Discussion
    Last Post: 04-05-2004, 07:03 AM
