Results 1 to 7 of 7
Thread: Mercury Gear Set
10-30-2019, 03:19 PM #1
Mercury Gear Set
Looking for a clean undamaged complete set (fwd pinion rev) of merc inline 6 straight tooth 2:1 gears. Thanks alot
10-30-2019, 06:53 PM #2
Screaming And Flying!
- Dec 2001
- 6,677
- 101
- 600
how about a whole lower unit?.... what year ya working on?......
10-30-2019, 07:18 PM #3
I just need the gears bud. Dont have much use for the entire case. Thanks for the offer sir
10-30-2019, 08:41 PM #4
- Dec 2001
- 6,677
- 101
- 600
There are 2 types of pinion splines..... which do you need?
11-01-2019, 10:15 AM #5
Pm sent
11-01-2019, 05:51 PM #6
- Dec 2001
- 6,677
- 101
- 600
I didn't get a PM......just the first one......looking at L6 shafts and gears, the early shaft had 6 splines.... the later ones had 17 splines....V6 pre/load has 11 splines and a bigger gear/tapper..... The 17 spline has a cut above the splines that would be a week point.....If you want a better D/S the latter 3 and 4 cly loopers have no week point above the splines.You would have to have it cut to work.....All seem to have the same lower bearing out side dia.......
11-01-2019, 06:29 PM #7
Mr dave you are correct, the older models used a much smaller pinion area on the drive shaft. Im looking for the later model that has the larger pinion. The Pinion gear im looking for will have 17 splines on the bottom of drive shaft profile. Thank you sir
mercury 1.87 gear set
By Cal 47 in forum Lower UnitsReplies: 7Last Post: 04-07-2015, 05:47 PM
