Page 3 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 31 to 45 of 70
Thread: Wmv 18 carbs
  1. #31
    May 2014
    Livingston, Louisiana
    They definitely idle smoother and cleaner. I fought them either stumbling or bogging on take off. Could tweek on them to where they where perfect that day. Come out another day they would either stumble or bog. Always ran good on big end just inconsistent on take off. Sance (T-Tex) told me he fought the same issues and convinced me to give up. But I’m kinda stubborn and won’t to figure it out.
  2. #32
    Sep 2017
    Ashland city tn
    Did u run the thermal air valve? I dont have the valve and wondering what I should do bout that. Or maybe that's the bog issue
  3. #33
    May 2014
    I ran it, if I remember correctly I unhooked it when it would stumble from being rich on the transition with no change (or at least I did on some motor). As long as the cooling system is working properly valve shouldn’t be doing anything above 100 degrees.
  4. #34
    Sep 2017
    Ashland city tn
    So I should least b able test without the valve and just leave the end of the hose open?
  5. #35
    Jan 2018
    Alabama
    Open equals "lean" so keep that in mind. The valve is closed and blocks air to the orifice when below 100 degrees so the engine gets extra-rich mixture when warming. Once the thermal valve hits 100 degrees, the valve opens and allows the hose to deliver more air to the mix. Gordon
  6. #36
    Sep 2017
    Ashland city tn
    Ya I get that part. but up to 100. It's just gona b idling neway.
    After 100 its open with full air. Dont c how it could lean it out to b dangerous.
  7. #37
    May 2014
    You’ll be fine, valve only restricts air to idle circuit below 100. Off idle won’t effect enough to hurt. Just will be a little cold natured.
  8. #38
    Sep 2017
    Ashland city tn
    Good deal. I wanna give em a test run b4 I buy that valve to c if I even like em. Thanks
  9. #39
    Sep 2017
    Ashland city tn
    The 18s wont fit under a xri cowl with a 1 in spacer unless mod the cowl at bottom which will have a space to take in water and feed bottom carb which we dont need. I'm gonna stop playin wit chit til I get a diff cowl for this mota. I'll prob leave it b and put all this effort in new mota and boat restore ,,
  10. #40
    Feb 2014
    Missouri
    If you could get them I think you would enjoy a 6pack if wo-8 anyway. Would look sweet with velocity stacks and spacer. (If you like the 6 carbs vs 3 look)
  11. #41
    Sep 2017
    Ashland city tn
    I'm little slow today dont understand 1st sentence haha
    I've had the carbs
  12. #42
    Feb 2014
    Missouri
    Yea that was in a Hurry, think I got auto correct as well.
    Was as wondering if you ever though of running the wo-8 carb from the 250-275 it’s a 6 carb set up or 6pack. Their pretty much nla. they were nice though no air jets just low and high and plenty of flow.
  13. #43
    Sep 2017
    Ashland city tn
    Well It would look good neway. But dnt think I'll b doin that haha
  14. #44
    May 2015
    Southwest Georgia
    Don’t know if this will help but here is a shot from the manual on my 2002 200 hp Mercury for the V 18s.
    Attached Thumbnails Attached Thumbnails 8C1A0D24-EA71-435B-96BA-3656F80B436F.png
  15. Thanks Merc 2.5 thanked for this post
  16. #45
    Sep 2017
    Ashland city tn
    Well the 18s wouldnt fit with a spacer and this cowl. So I took a sand disk on grinder to bowl on bottom carb had lots extra metal n the way. Its together and runnin. will try test soon as weather and time/work allows
  1. 200 WHM 1A carbs on a 1990 merc XR4 that had WMH 1A pumper carbs
    By BASSCASTER in forum Technical Discussion
    Last Post: 07-07-2014, 11:26 AM
  2. OMC Tech: Older 75hp evinrude carbs vs 86' 70hp johnson carbs
    By roycesrolls in forum Technical Discussion
    Last Post: 06-01-2012, 08:24 PM
