Page 2 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 16 to 30 of 70
Thread: Wmv 18 carbs
    Sep 2017
    Ashland city tn
    It's just a carb. Not rocket science haha. Didnt mean stir up chit. I've never ran a set of these wmv and just gonna do sum experiments, the mota ain't stock ,so all stock jetting pretty much out window neway. The mains I'm not concerned bout it's the idles I'm curious bout and y they r all over the place and if I should say ,throw in sum 48s for idlez and c what it will do
  2. #17
    TX......somewhere?
    this might help.... copy and paste.
    http://www.corboatracing.com/downloads/wmv-wmh-carburetors-mercury-manual.pdf
  3. #18
    Jul 2002
    FT WORTH, TEXAS
    wmv 5 are NOT jetted like wmv 18 period
  4. #19
    Jul 2002
    FT WORTH, TEXAS
    if you just look up boats .net you will find every question answered on carb jetting its a use full tool for every kind of question except mystery stuff from Merc u will find very small air jets in the 18's the later the model more is different
  5. Thanks Merc 2.5 thanked for this post
  6. #20
    Sep 2017
    Ashland city tn
    So I found it on boats net. But only gives me 5 mains and 5 idles. Missin 1 for ea. Which I think I can figure that part out.
    Idles are .038,.032,.028. Mains 80 ,82 ,84. Wow. All over the page.
  7. #21
    Feb 2014
    Missouri
    Yep.
    135-150 run all the same on one side no idea why it’s flip flop on higher hp.
    I had motors confuesd. Tay it was the two designs on the choke plate that are different after 30 years things get jumbled but glad your sticking to it. Looks like we we managed to wrangle out all thoes lean number 6 issues though with people only running .82 -.80 instead of .84.
    Sorry merc 2.5 this thing got on your question.
    If your willing to trust my memory (it’s faulty). I think it’s an .82 fuel pb and I can’t remember if idle air was .28 or .32. Bowls .86 air
    marine engine matches boatnet. 135 has all the same main fuel, airs are different the 140-mag3 keep starboard the same. 200 has all weird.
  8. #22
    Jul 2002
    FT WORTH, TEXAS
    yep now your cookin i just looked up late models it has 3 differrent air jets and .084,.082.080 mains on selected cylinders which if your a old school guy 2 and 5 always ran bigger jets
  9. Likes bullet123 liked this post
  10. #23
    Sep 2017
    Ashland city tn
    Quote Originally Posted by TEXAS20225 View Post
    Ya that's what I was thinkin , well for 2.4 neway. When james did my bassboat block said they should all run same (or real close)on my 2.5 neway with wh46 carbs , and it ended up at 86s on all 6 (safe side) and doin good. But since the wmv are all over the place. not sure if I should try say 84s across the board and see what it does. or should I just step up each cyl according to what they were stock also same with idles? 1 size across board or step up according
  11. #24
    Sep 2017
    Ashland city tn
    It's been so long since I looked at these carbs. All the idles r in it from stock. (Little jets) tiny jets for idles. I removed mains long ago but still have them. I think I'll try 1 size mains and c what they do
  12. #25
    Feb 2014
    Missouri
    I would say if going 6 the same go with 84. Better to just get it dirty then lean and boom.
    Their it shouldn’t be a reason you can’t. And with your stacks and no air box and spacer honestly we’re spitting in the wind.
    Going with what your builder said if you ran 18,s is good choice.
  13. #26
    Sep 2017
    Ashland city tn
    No he wasn't talking bout 18s. We talking about wh carbs.
    But with 18s and biggest jet being 82 and my modded motor. I'd think 86s andngo down. Motor been ported etc
  14. #27
    Sep 2017
    Knoxville, TN
    Good read guys, learned quite a bit.
    Respect no wake zones!!! Evinrude guys need a place to race too.
  15. #28
    May 2014
    Livingston, Louisiana
    The little I fooled with the WMV’s, went up proportionally on main jets from stock( added let’s say .006 to on the .080 to .086 and the .086 went to .092 and on down the line). Completely remove the backdraft jets to prevent surging and other drive ability issues. Didn’t mess with idles because hard to find those and took them off before getting them perfected because got tired of never knowing how take off would be on any given day and patience got slim. They idled cleaner and leaner which I feel was reason why take was so unpredictable from day to day. I also can say they ran harder on top end than my wh 20’s, but the wh’s left much harder. I’ve toyed with idea of playing with them again to see if can get take off better, but just don’t have the time.
  16. Likes Merc 2.5 liked this post
  17. #29
    Sep 2017
    Ashland city tn
    Yes sir u nailed it. Just wanna play with em and c what I get. I have all originals and some. I'll put em together sumtime this weekend and report back , slimm. Member here swapped to the 18s and said his ran alot cleaner and better milage , its also made his motor sound completely different than the wh
  18. #30
    Apr 2017
    pa
    5 Post(s)
    Yep. i am 2 sizes bigger on 2 and 5 on my motor.
  1. 200 WHM 1A carbs on a 1990 merc XR4 that had WMH 1A pumper carbs
    By BASSCASTER in forum Technical Discussion
    Last Post: 07-07-2014, 11:26 AM
  2. OMC Tech: Older 75hp evinrude carbs vs 86' 70hp johnson carbs
    By roycesrolls in forum Technical Discussion
    Last Post: 06-01-2012, 08:24 PM
