Page 1 of 5 1 2 3 4 5 LastLast
Results 1 to 15 of 70
Thread: Wmv 18 carbs
    Sep 2017
    Ashland city tn
    Wmv 18 carbs
    Can anyone point me in right direction for stock jetting for wmv 18 carbs , from 2.5 200? Any help appreciated. I wanna say the jets were all over the place but I'm not sure on these
    Jan 2018
    Alabama
    Here is the table from Mercury - Gordon
Name:	Carb Listing 5.JPG
    Sep 2017
    Ashland city tn
    Thanks gordon. Guess it was idle jets that were all over the place
    Sep 2017
    Ashland city tn
    Now I'm curious if anyone has put in all same main and idle jets , like.all 82s and 50 idle , would they still run rite ? I've got a set layin round and wanna put jets In em and give em a run
    TX......somewhere?
    best I remember I used same in idle's and same in mains in wh and wmh's.. never fooled with tha wmv's much.. was goin' ta horn stuff 'bout that time...
    Sep 2017
    Ashland city tn
    Thanks Tommy. I run all 86s and 48 or 50s now in wh carbs , I wonder y the jetting is all over for wmv? I'm gonna set em up like I got wh set up, and do few low rpm runs and check plugs/ pistons as I go I rekon. Bout only way I no to do it
    TX......somewhere?
    wmv's got to complicated for this simple 'ole man.... to many parts!
    Feb 2014
    Missouri
    Iirc if the carbs are balanced you can, if you have the two different size setup you have to balance them first (bit of a pain).
    theirs only a cupple unbalanced mercs though. Linkage or different size (link balance will normally have a carb less open at full throttle and smaller jet )
    balance can cause higher idles and loading.
  9. Likes Merc 2.5 liked this post
  10. #9
    TX......somewhere?
    got my curiosity button pushed now??? never heard of such a thing with any v6 merc... wh, wmh (wmv's, refer ta post 5) carbed merc??? jus which one ya talkin' about!.. maybe one of tha little motors?.. but none of those used either, of tha carbs mentioned???
  11. #10
    Jan 2018
    Alabama
    It is not unusual to have 1 or 2 cylinders that run richer or leaner than others from the factory. It could be airflow restrictions or lack thereof.
    My Evinrude V4 project motor calls for size 33 orifices in the idle circuit for cylinders 1, 2, and 3, but #4 (bottom port) calls for a 35. These are air bleeds, so the larger number means more air. This tells me that #4 is prone to run rich - probably due to bleed hose routing and #4 being at the bottom of the bleed system (excess fuel/oil drain/collection system), so be careful ignoring what the factory found during years worth of testing.
    Gordon
  12. #11
    TX......somewhere?
    i understand what ya sayin' but has absolutly nothin' ta do with a merc wh, wmh or wmv.. which are tha only ones merc use ona v6.. which is what was asked!... so why even bring it up? I don't understand...
  13. #12
    TX......somewhere?
    whats so hard 'bout readin' above????.. granted I included wmv's and shouldn't have.. why bring in "different size and/or adjustment linkage, some open more that others junk in this thread also??? that's how newb's get ta lookin' for **** that aint there.....
  14. #13
    Feb 2014
    Missouri
    My charts show wmv18-1,2,3 running .80 st,pc .82 pt,sc and .84 bs with iaj .28 cs, bs, and cp .32 bp and .38 tp no idea why it’s not giving me the 6th jets.
    As for linkage its just design 1 or design 2
    iver thirty years you just see odd stuff not always factory.
  15. #14
    TX......somewhere?
    there is no carb linkage made for tha V6 merc that move one throttle plate more or less than tha other or at more or less speed of tha others that I've ever seen.. that's goin' all tha way back to my first (in 1976) 1750 V6???.. would like ta know more?
  16. #15
    Sep 2017
    Ashland city tn
    Will u post that chart if u can?
  1. 200 WHM 1A carbs on a 1990 merc XR4 that had WMH 1A pumper carbs
    By BASSCASTER in forum Technical Discussion
    Last Post: 07-07-2014, 11:26 AM
  2. OMC Tech: Older 75hp evinrude carbs vs 86' 70hp johnson carbs
    By roycesrolls in forum Technical Discussion
    Last Post: 06-01-2012, 08:24 PM
