Results 31 to 45 of 55
  1. #31
    Dec 2010
    Denmark
    Chaz,
    I like your sugestion,,,,
    However some of the high quality slight used once normal have more experience in the pin in and out thing. Hope you know
  2. #32
    The pistons Santa has are ggood...... I like Mahles.....Chazzzz is that ABBA cloned....?????
    I just got off the phone with Robert Palmer ... he said he didn't know where the money went... Now he can't afford a new set of Mahle's and gold rings for all ............>
  3. Likes powerabout, rgsauger liked this post
  4. #33
    Gothenburg, Sweden
    Quote Originally Posted by A164 View Post
    Markus send me som pictures. If they are better than mine, and the price is right, I might be interrested.
    From what you have described about your pistons so far in this thread, I would bet that they are better.
  5. #34
    Dec 2001
    Chazz ya got me in a dancing MOOOD....I taka off my pants now..... an DANCE...
  6. #35
    Gothenburg, Sweden
    Please, no pictures.__PRESENT
  7. #36
    Quote Originally Posted by Markus View Post
    I'll have to second that ...... Dave, stay inside the shack ......
  8. #37
    Dec 2010
    Denmark
    Dont get dizzy now,,,
    https://www.youtube.com/watch?v=y_6Vh_-3Gcs
  9. #38
    Dec 2010
    Denmark
    What I mean is that they are in good shape.
    I can send some pictures later this week.__PRESENT
    Hey Markus,
    Did the bikini team team hide piston skirts so you can not find them now,,,,,,
  10. #39
    Dec 2010
    Denmark
    I desided to go for new pistons and got a nice set of top pinned pistons through JSRE. And they are now assembled in my block. Prewiosly I had a compression between 131 - 135 psi, now I got between 145 -152 psi. I also went for the thinner head gasket (0,75mm). I only been running the engine in my small water tank, just to adjust idle timing end so.
    I am looking forward to get out on the water, to see if there will be some improvements in power. I know I have to make a brake in time, so after that its WOT time,,,,,.
  11. #40
    Dec 2010
    Denmark
  12. Likes Merc 2.5 liked this post
  13. #41
    Sep 2002
    Solvang, Calif
    Why I went to top pin.
    Had to send the first set back cuz they were drilled to deep, leaked into crankcase. Then later this happened.
Name:	Top Pinned Piston 001.jpg
ID:	461601Click image for larger version.
Name:	Top Pinned Piston 002.jpg
    Yes this was decades ago.
Name:	Why I top pinned pistons.jpg
    Gary
  14. #42
    Did you use that ducting to run central heat thru the house this winter ..
    Did the ring ends butt together .. ?
  15. #43
    Sep 2002
    Solvang, Calif
    If I remember correctly(I've slept since then)they were ground round to match the pin. Before installing I checked the end gap to see if they were within spec.
    Gary
  16. #44
    Tennessee River
    Those are side pin rings trying to run on top pin pistons.
    Only the little tits at the bottom of the ring are touching the pin before it failed.
  17. #45
    Dec 2010
    Denmark
    Found a couple of Break-in procedures. It seams that they are different, depending of who you are talking to. And between us Pirates theese are more guidelines than ruels,,,,
Name:	Break-in 25 EFI Offshore.JPG
ID:	461708Click image for larger version.
Name:	Break-in 25 EFI.JPG
    Year I know, I know,,, can not just fly and scream ad once so i will behave and do my best to be gentle and follow the guidlines.
  1. Festivis explained!
    By Robby321 in forum The Scream And Fly Lounge
    Last Post: 12-23-2018, 04:15 PM
  2. Tools explained
    By euro scott in forum The Scream And Fly Lounge
    Last Post: 03-19-2013, 10:02 PM
  3. BP well explosion explained
    By CDave in forum The Scream And Fly Lounge
    Last Post: 07-27-2010, 08:10 AM
  4. Bailout explained
    By Forkin' Crazy in forum The Scream And Fly Lounge
    Last Post: 12-11-2008, 10:54 PM
