Results 16 to 30 of 55
Thread: Need Top Pin Piston Explained
11-14-2019, 06:50 PM #16Screaming And Flying!
- Dec 2001
- 9,502
- 271
- 191
- 1976
if ya make the exhaust port friendly to the rings.........balanced ring return..... the pin will be happy......
David Borg, RBT liked this post
11-14-2019, 08:00 PM #17Markus' Performance Boating Links:
11-24-2019, 01:03 PM #18Member
- Dec 2010
- Denmark
- 98
- 9
Need of pistons.
I share your concerns as I did a semi overhaul of my 260 HP outboard over 5 years ago. allot of parts was changed but I did not change the pistons, well knowing that I had some issues with loose piston ring aligning pins.
What I did was driving the pins back to the original point, and used an untraditional way to kinda lock the pin there. I forced some of the aluminium by using a punch and a hammer to lock it in place.
This I did because I was not ready to spend the money for new pistons at that time. And my use of the engine has been in the rpm range up to 7500rpm. mostly running lower. So 5 years after my overhaul in 1914 I now took my engine apart, finding my pins still in place. however looking to have been some movements. So I am thinking it must be time for some new pistons, so that I can sleep better, so I am now in the market for a good solution to my engine. Anny one know where to find replacement pistons?
11-24-2019, 03:48 PM #19
Pro Marine ..
http://parts.promarineusa.com/scategory/M50/1/1/30/205
David Borg liked this post
11-25-2019, 02:12 AM #20Screaming And Flying!
- Dec 2001
- 9,502
- 271
- 191
- 1976
I like the fact that ya worked the piston....That's what you do when parts aren't easy to get..........If the pins were falling out.......ya could pull en like a dentist.... then do your own top pin........But new is easyer.
vtboy liked this post
11-25-2019, 09:23 AM #21Markus' Performance Boating Links:
11-25-2019, 12:42 PM #22Member
- Dec 2010
- Denmark
- 98
- 9
Chaz,
Good suggestion. But are this a good longtherm solution.
Dave S,
Most thing are easy to get if you want to spend the money. In my case I wanted to deside whether this engine was something for me, before spending the money for new pistons. For my use where im running in the pattern 5% idle, 15% at 2000-3500rpm, 55% at 3500-6500rpm, 25% at 6500-7500rpm. (just a rough estimation acording to my gut feeling). I found very little / almost no wear on all the new parts that I put in 5 years ago. I may have had an average of engine running of max 15hr pr year. You might say that this engine is not for my kind of use, but I like the fact that the high performance is there when somone challang me. Kind of sleeper consept on my Maxum 2000 XP boat.
Markus
When you say good used pistons, it sounds for me that they have been used fore a quite long time. (godt brugt på (Danish) betyder jo noget der godt slidt). Sorry for the language change, as I expect Markus beeing Swedish reated I assume that he can understand some Danish. :-)
Maybe you can send me some pictures?
11-25-2019, 12:47 PM #23Member
- Dec 2010
- Denmark
- 98
- 9
Just forgot to meantion, All parts that I used 5 years ago was purchsed from Jay.
http://www.jaysmithracing.com/index....tpage&Itemid=1
11-25-2019, 01:15 PM #24Member
- Dec 2010
- Denmark
- 98
- 9
Replaced parts 5 years ago:
Redone crank fron JSRE.
Lightend connecting rod.
High performance encapsulated light weight wrist pin.
Bearings.
Reeds.
Miss gaskets. etc.
11-25-2019, 01:36 PM #25
Ohh long term ... naww, I put a bunch of used **** in there with collapsed skirts, lifted ring lands, and pins that are ready to fall out ...
I just got off the phone with "The Sweedish Bikini Team" (you know they are American .. right)
They said, if they are gonna ride with you, they expect a brand new set of coated pistons from a hi-volume, stocking warehouse that will give you a good price, that ships word wide every day ...
David Borg thanked for this post
11-25-2019, 05:17 PM #26Screaming And Flying!
- Dec 2001
- 9,502
- 271
- 191
- 1976
chazz ya kinin me........Omodhohho
11-25-2019, 05:19 PM #27Screaming And Flying!
- Dec 2001
- 9,502
- 271
- 191
- 1976
ya be besttuin the not....ladddies......
11-26-2019, 09:01 AM #28Markus' Performance Boating Links:
11-26-2019, 10:21 AM #29Screaming And Flying!
- Dec 2001
- 9,502
- 271
- 191
- 1976
The pistons Santa has are ggood...... I like Mahles.....Chazzzz is that ABBA cloned....?????
11-26-2019, 12:34 PM #30Member
- Dec 2010
- Denmark
- 98
- 9
Festivis explained!
By Robby321 in forum The Scream And Fly LoungeReplies: 2Last Post: 12-23-2018, 04:15 PM -
Tools explained
By euro scott in forum The Scream And Fly LoungeReplies: 9Last Post: 03-19-2013, 10:02 PM -
BP well explosion explained
By CDave in forum The Scream And Fly LoungeReplies: 19Last Post: 07-27-2010, 08:10 AM -
Bailout explained
By Forkin' Crazy in forum The Scream And Fly LoungeReplies: 6Last Post: 12-11-2008, 10:54 PM
