Results 1 to 15 of 18
    Jun 2012
    Indiana
    Pistons: Mercury vs Wizards vs CRT
    I am in the process of doing a rebuild on a stock Merc 2.5 260. I have used Mercury and Wizards in the past and have had good luck with both. I also see that CRT is selling there own brand of pistons and was curious what others think. I would prefer to stick with OEM stuff but the Wizards are considerably cheaper and I believe the CRT's are as well. Any info greatly appreciated.
    shreveport,la
    The Mercury piston would be my first choice, second would be the CRT piston as long as it accepts the Mercury ring
    Erik Kiser
  3. Likes tlwjkw liked this post
    Tennessee River
    If you really like the OEM product we/Wizard have been making a piston that is virtually the same as the Merc it even uses the Mercury ring. The tunnel boats racing overseas have been using them for years.
  5. Likes Dave Strong, racer, Glasstream15 liked this post
    Mar 2004
    Brooklyn Park, MN
    anyone use Glenn Reynolds pistons?
    1973 Viper - sold
    1978 Viking - sold
    1995 XB02
    Jun 2012
    Indiana
    Reason Im asking is the wizards can be bought for about $450 less. I have a set in a 280 Im running on my Allison. It only has 26 hours on it but it runs great. Not trying to be cheap but if I can get comparable pistons for that much less than that's what id like to do. Didn't know the Wizards take merc rings though. Anybody run the CRT's yet? Appears to be made by Wiseco. Appreciate all info!!
    Tennessee River
    The light weight 2 ring Wizard takes the Wizard ring.
    The single ring piston that is more like the OEM Merc takes the mercury ring.
    The tapers are different on the two.
    May 2001
    Hickory NC
    Have run the Wizards in a couple endurance races in Parker. They looked really good afterwards and went right back in.
  10. Likes ProComp liked this post
    Feb 2005
    Muskoka Canada
    Might as well throw Woosner in the mix.
    2023 TUFF 25
    Jul 2015
    northern lower michigan
    Quote Originally Posted by RBT View Post
    There popular with some higher end after market 2-stroke big bore kits in snowmobiles.
    Jun 2018
    Floating around
    Vertex?
    What seems to be the question to ask is best piston for the $?
  14. #11
    Jun 2012
    Indiana
    Vertex?
    Yes that's the question. Being a 260 it will see 8k regularly are vertex cast or forged?
    Jun 2018
    Floating around
    I believe Vertex are cast
  16. #13
    Jul 2005
    AZ
    Vertex are both
    Vertex pistons are both cast and forged. Vertex casts their two stroke pistons because of the ability to incorporate higher silicon content into castings as opposed to a forging. This gives the piston a lower thermal distortion characteristic and higher wear resistance. Vertex uses castings and forgings in its four stroke pistons depending on application. Low rpm, low performance four stroke engines can use cast pistons. High performance, high rpm engines (like today’s race bikes) use forged pistons for strength. Vertex has the ability to manufacture its pistons to suit each need.
    '84 Checkmate Convincor
  17. #14
    Mar 2004
    Brooklyn Park, MN
    anyone know the Vertex 260 piston part number? Also, I have a set of top pinned wizards but I am looking for a part number for a +.024 and +.044 wizards. I called pro marine and i must have got the new guy as he looked in the catalog and said they don't have them. I would guess they do but he didn't know as they don't list oversize in the catalog.
    1973 Viper - sold
    1978 Viking - sold
    1995 XB02
  18. #15
    Tennessee River
    rjdubiel. What is the part number on the Wizards you have?
    We make a piston for Pro Marine that is more like a stock 225 piston.
    The others are lighter and more like the 260 piston.
  1. WTB USED wizards
    By MUDSHARK in forum Misc. Parts and Accessories
    Last Post: 10-31-2017, 05:04 PM
  2. OMC Wizards??
    By Naiscoot in forum Technical Discussion
    Last Post: 06-18-2007, 07:00 PM
  3. Omc Wizards!
    By Instigator in forum Technical Discussion
    Last Post: 07-10-2002, 12:32 PM
  4. ANY G.M. Wizards out there??
    Last Post: 11-10-2001, 08:49 AM
