Results 16 to 30 of 33
08-21-2020, 10:52 PM #16Mirage Jaguar RiverRacer
Polaris PRO785
Bennington 255LCC
Scream & Fly Flying Machine of the Month: September 2005
http://www.screamandfly.com/showthre...ild&highlight=
08-22-2020, 07:59 PM #17
MODVP22 liked this post
08-22-2020, 08:06 PM #18Mirage Jaguar RiverRacer
Polaris PRO785
Bennington 255LCC
dgscroggs liked this post
08-22-2020, 08:14 PM #19
Has he run it yet?
Boat Delivery available
Things owned. NOTHING!!
08-23-2020, 08:13 AM #20Mirage Jaguar RiverRacer
Polaris PRO785
Bennington 255LCC
08-23-2020, 05:37 PM #215000 RPM
- May 2001
- Maine
- 982
- 35
- 42
- 170
What's he running for a prop, the Promax from the previous owner, if so let us know how it performed as I have been thinking of what one would do on a Euro..
09-10-2020, 06:55 PM #22New Member
- Oct 2002
- massillon,ohio
09-10-2020, 07:29 PM #23Supporting Member
- Apr 2003
- New Smyrna Beach, FL./LOTO
- 6,641
- 606
- 920
- 1698
- 7138
- 3 Post(s)
You don't need to run the boat high like a Mirage. With that power, I would find a 26 or 28 Pro ET and it will cut your learning curve in half. A 32 is a big wheel for a euro/promax combo especially if you have any passengers. Over trim it to 70 then get on the down button gradually "as you roll past 90 you should be right at neutral" then slightly tucked when its packing good air at low 90s and up. Look down the inverted V (from the bow with the boat and prop shaft level) and make sure you can just see a glimpse of the water pick-up-that should be your optimum motor height unless you have more then 6" of set back, then you can go a little higher and still have pressure.
09-10-2020, 07:37 PM #24
Joe, a 26 is only going to get low80's on the limiter. Needs a 30-32
09-10-2020, 08:57 PM #25Supporting Member
- Apr 2003
- 6,641
- 606
- 920
- 1698
- 7138
- 3 Post(s)
I put lots of hours on a promax at 7400 with a 1.87 and a 26 or 28. Unless its really flat water you don't run faster then that for extended periods anyway. Most people don't have the river that we do and are forced to deal with lake traffic. It will make it a more user friendly rig.
FAST RALLY SPORT liked this post
09-11-2020, 01:50 PM #26
Nice weld!
09-11-2020, 02:35 PM #27
That looks like a fatigue failure of a casting possibly due to porosity. The photos of the fatigue areas are not 100% clear. The grainy portion is the catastrophic failure point. The smoother parts that look like where waves washed up on beach sand lead to the place where the crack started. As the surfaces on either side of the crack "worked" against each other they made those marks. Once the remaining metal no longer had the strength to hold on, it all broke off at once and that's where it's grainy. Better pics would help clarify that but I guess since you don't have the prop anymore...
Josh Peterson
09-11-2020, 04:56 PM #28
Congrats on your purchase....I was the owner who traded it to Randy for a 22 Liberator. I loved that Euro, planned on keeping it for ever.....but plans change. LOL
Just a couple of points, boat had a 29p Promax non labbed prop when I traded it to Randy, the fastest the boat ran was 94 mph with that prop. It worked well got on plane great, accelerated great and carried weight well. I used it as my everyday prop. I didnt like the 6750 soft rev limiter on the Promax, I put a Bruncato Box on it with a 7200 rpm limiter and ran a labbed 30 ET Lightning prop and the boat ran 98 mph that was the speed on the recall when I traded it. Boat was rock solid with the ET Lightning never did anything unpredictable. When it was traded everything was back to stock ECU and Flywheel. Those numbers were run with a nose coned 200 gearcase with a welded torque tab....which I still have in my garage. The Sport Master gearcase thats on it, I bought and put on to run and keep the other gearcase as a spare. Boat was a little slower with the sport master, but they are more durable than the stock coned gearcases. Never got finished dialing the motor height in when I traded it. Its close, but I think it could still go up about 1/8 of and inch.
Have fun...boat was good to me, wife just didnt like riding in it, she never went over 60 mph in it. Just didnt like sitting down on the floor.
10-02-2020, 06:53 PM #29New Member
- Oct 2002
- massillon,ohio
Progress
I wanted to thank all of you for your experienced insight and information on my Euro. I ran it again and couldn't get the hop out, even trimmed down at 90 it would just get so violent I had to get out of it. I leveled the boat on the trailer and leveled the prop shaft. With a straight edge from the pad to the center of the bullet was 2 inches. Everything I've read says that's too high. I lowered it 1/2 inch and ran it a couple weekends ago. It was solid and stable at 96!! Now I have all winter to find 4 more mph!
10-02-2020, 07:42 PM #305000 RPM
- May 2001
- Maine
- 982
- 35
- 42
- 170
How was the mid range bounce when you lowered the motor, any improvements or just better handling on the top end?
2018-2019 ocean express catamarans available thru offsheperformancenetwork.com
By FSTBTS in forum General Boating DiscussionReplies: 3Last Post: 04-15-2019, 12:10 PM
