Results 91 to 105 of 113
Thread: 200 Black Max Low Water Pressure
11-13-2019, 07:03 PM #91
Just fyi, were using the buzzer and trying to put a hand on the hands to judge temp right now. At idle before we go out you can hold your hand on the head. After the buzzer sounds you cannot hold your hand on the head. Also it overheats very quickly, I would say 10-15 seconds after the hole shot it gets too hot.
Respect no wake zones!!! Evinrude guys need a place to race too.
11-13-2019, 07:57 PM #92
Ya laser work fine
11-13-2019, 08:12 PM #93
If we give up on this motor whats it worth to sell? We would be forthcoming with the overheating issue. Were just trying to get the gambler back in the water and now we have 2 engines with problems because the seller wasnt forthcoming.
11-14-2019, 12:38 AM #94
At this age it should have had new head gaskets anyway, but 143 is very warm to the touch.
11-14-2019, 12:41 PM #95
Yeah its warmer than that cap lol.
11-14-2019, 06:10 PM #96
Ok so we finally caught the villain infesting the 2.4. We knew everything was right cooling wise so we took a deep breath and dropped the heads. We started to shoot it with a thermometer but knew there was nothing left but something inside the block. Two cylinders have bad discoloration and those pistons are starting to pit from heat soak. I believe the guy who put the engine back together with the wrong adapter plate must have not had an engine alarm and drove it like this for a little while or just ignored the alarm. So this motor needs rebuilt too. Lesson learned, anytime we buy any other engines a thorough evaluation will take place before we purchase. Wish more people would use manuals instead of just throwing things together. We managed to find a decent older 2.4 powerhead were going to look at to try and get us by while the promax is getting built. We will do a full compression test and thermal scan. I want to thank everyone for their help. We learned a lot from this little endeavor that will make future troubleshooting and engine buying easier for us. Plus we can now jerk a powerhead in less than 10 minutes lol.
11-14-2019, 06:16 PM #97
I agree sumthin wrong. The pitting is normal for chrome bores
11-14-2019, 07:16 PM #98Respect no wake zones!!! Evinrude guys need a place to race too.
11-14-2019, 07:32 PM #99
Bores have pits or are the piston tops eroded? Chrome motors always have pits.
11-14-2019, 08:39 PM #100
11-14-2019, 11:13 PM #1016000 RPM
- Feb 2014
- Missouri
- 1,212
- 66
- 12
- 83
With the water working, it was probably lean, dubble check the color isn’t ashy stained. But physical damage pretty much ends it till a piston swap
good of luck on getting her going.
TNRoostertail liked this post
11-15-2019, 08:18 AM #102Respect no wake zones!!! Evinrude guys need a place to race too.
11-15-2019, 10:51 AM #1035000 RPM
- Feb 2009
- Dunnellon, Fl. / Cincinnati, Oh
- 419
- 62
- 28
- 136
- 162
Did your block water diverters look to be in o.k. shape and in the right spots when you pulled the heads?
If it's not too much to ask, could you shoot a couple pics of your discolored / pitted chrome bores and diverter shape / locations in block? Thanks!
11-15-2019, 11:01 AM #104
Here yah go, the camera isn't quite clear enough on some pics. In person you can definitely see the discoloration where the chamber was getting hot.
rochelle howell thanked for this post
11-15-2019, 11:05 AM #105
This engine was supposed to be in "good" shape. Guy said he just put it back together etc... We learned to always do a full work through from now on unless purchasing new or from a verified source. This engine was just meant to "get us by" while we rebuilt the promax. This engine was also 1500 bucks, and that's a good price imo for an older 2.4 that's running good.
high water pressure problem on a black max
By mouse4x4 in forum Technical DiscussionReplies: 50Last Post: 05-16-2013, 09:41 PM -
Mercury Tech: what would be good water pressure for an 88 200 black max
By concord 1 in forum Technical DiscussionReplies: 6Last Post: 07-09-2009, 08:32 AM -
Black Max XR-2 150 / No water pressure to gauge!
By Rush in forum Technical DiscussionReplies: 16Last Post: 02-06-2005, 08:18 PM
