Results 76 to 90 of 113
Thread: 200 Black Max Low Water Pressure
11-11-2019, 03:14 PM #76
Well motor is still getting too hot. Idk what else to do unless the mid plate is wrong, or we have a problem in the heads.
Respect no wake zones!!! Evinrude guys need a place to race too.
11-11-2019, 04:16 PM #77
Well I think I we got it. Took the power head off again because I didnt like the look of the mate up on the adapter plate. Our engine is a 2.4 200, adapter is 2.4 but the exhaust bracket that the tuner bolts too is not. I believe it's a later model 2.5, it doesnt line up at all with gaskets. How can I get my hands on a 2.4 exhaust plate? I dont need the tuner.
11-11-2019, 04:31 PM #78
You can't put a 2.4 on 2.5 exhaust plate. There in is where your problem lies.
TNRoostertail liked this post
11-11-2019, 06:26 PM #79
11-11-2019, 06:32 PM #80
Not sure if I have pair of plates here at home to show the difference.
11-11-2019, 06:47 PM #81
11-12-2019, 09:31 AM #82
We found a 89 2.4 mid local. It has the exhaust plate and tuner along with newer trim. I'm snagging the tuner, mid and trim my buddy is taking the plates. Should work out ok.
11-12-2019, 09:32 AM #83
U dont want the 3 ram. Keep single ram if that's what u got
11-12-2019, 10:42 AM #84
3 ram is much better for recreational purposes. Yeah you can't mismatch plates like that.
11-12-2019, 11:21 AM #85
I have the single but I'm swapping to the newer boat and dont want the trim pump and all that stuff in my storage area if possible. It's a 17.5 boat and storage is limited.
11-12-2019, 04:11 PM #86
11-13-2019, 07:26 AM #87
Well merc turned out to be another single ram. I will holler atcha as I'm not taking it.
11-13-2019, 04:53 PM #88
Ok we got the water pressure issue sorted out. On the lake now, holds 4-5 at idle and then a steady 15-20 wot. It's still overheating though. I'm pretty confident it's not a water issue now, the stats are opening and expelling hot water and pressure is very good. Could this be a timing issue? The guy that put this motor together before we got it obviously skipped some steps lol. What else could it be?
11-13-2019, 06:41 PM #89
Do you have an infared temp gun?
11-13-2019, 06:59 PM #90
high water pressure problem on a black max
By mouse4x4 in forum Technical DiscussionReplies: 50Last Post: 05-16-2013, 09:41 PM -
Mercury Tech: what would be good water pressure for an 88 200 black max
By concord 1 in forum Technical DiscussionReplies: 6Last Post: 07-09-2009, 08:32 AM -
Black Max XR-2 150 / No water pressure to gauge!
By Rush in forum Technical DiscussionReplies: 16Last Post: 02-06-2005, 08:18 PM
