Results 61 to 75 of 113
Thread: 200 Black Max Low Water Pressure
10-31-2019, 06:42 PM #61
They metal plate is in water pump we talking bout , but base gasket is power head gasket we talking bout. Gonna need check that I'm afraid
11-01-2019, 08:40 AM #62Screaming And Flying!
- Jul 2002
- FT WORTH, TEXAS
- 8,031
- 9
- 146
- 313
- 503
no not the base gasket for power head but base gasket for lower half of water pump most people dont change that part of the pump for what ever reason but just the impeller and the two gaskets and metal plate if you pull up lower part of pump you will see the base gasket for thats part of the pump that what was backwards sorry for the confusion
Merc 2.5 liked this post
11-01-2019, 08:46 AM #63
Oops sry. I misunderstood
11-06-2019, 03:34 PM #64
Ok guys, we completely redone the water pump new housing new seals new everything. The mid gaskets are all new. We flushed the engine. Dang thing still wont hold more than 5psi. Were lost and about over it lol. Anybody want to buy a black max lol.
Respect no wake zones!!! Evinrude guys need a place to race too.
11-06-2019, 03:49 PM #65
Only thing that bothers me is how much water is coming out of the top 2 exhaust vents. This is a 200 powerhead, and the mid is a 150. Could the adapter plate be causing problems? Were lost
11-06-2019, 03:52 PM #66
Here is a video
https://youtu.be/7_EcaIRitkARespect no wake zones!!! Evinrude guys need a place to race too.
11-06-2019, 04:17 PM #67
Think we may have our answer, started looking at gaskets that were on the mid originally. They are 92 and up gaskets, this mid is an 86 according to the serial. The gaskets for the mid to powerhead are completely different in the pics I can find. So we have the wrong mid gasket. Would this cause our problem? Thanks
11-06-2019, 04:35 PM #68
Yes wrong gasket will direct water to wrong spot. 5 psi at idle?
11-06-2019, 05:17 PM #69
A little less Merc but close.
11-06-2019, 05:19 PM #70
Mine idles round 1lb ,,sumtimes dont read in idle goin out no wake , at wot. U want no more than 15lbs. If ur 3-5lbs idle ur good
My guage could b off little but idle pressure should b under 5lbs
11-06-2019, 05:21 PM #71
I think that's 1 reason I blew my 1st 2.4. I had way to much pressure and water didnt have time pull heat out of block
TNRoostertail liked this post
11-07-2019, 06:47 PM #72
Well we got the new gasket on tonight that matches the mid. Psi is still low around 2-3lbs at idle. I will say this, when we run the throttle up it sucks the hose dry and doesnt give a good psi reading. It didnt do this before so were going to lake test and see what we have. Also ran compression test just to make sure we didnt have a bad head gasket etc.. Motor was from 117- 119 on all 6.
11-08-2019, 07:23 AM #73
Ok rooster. I will say it again haha. That is perfect pressure for idle. What kinda pressure u lookin for at idle? More pressure isnt good. When u drop n lake and put in gear at idle it will drop little more but that's fine to. U have normal pressure
Also when u do get to wot. U dont want more than 15lbsLast edited by Merc 2.5; 11-08-2019 at 07:25 AM.
11-08-2019, 07:56 AM #74
11-08-2019, 08:22 AM #75
high water pressure problem on a black max
By mouse4x4 in forum Technical DiscussionReplies: 50Last Post: 05-16-2013, 09:41 PM -
Mercury Tech: what would be good water pressure for an 88 200 black max
By concord 1 in forum Technical DiscussionReplies: 6Last Post: 07-09-2009, 08:32 AM -
Black Max XR-2 150 / No water pressure to gauge!
By Rush in forum Technical DiscussionReplies: 16Last Post: 02-06-2005, 08:18 PM
