Results 1 to 12 of 12
    Lake Coochiching, Ontario
    Opti spark plugs are black
    I just finished year two with my 200XS ROS. Great motor. Year one, break in and maybe another hour, the plugs came out black. Year two, ran a few tanks of gas through it, plugs came out black when I pulled them to fog the motor.
    Is this normal?
    Sep 2017
    ontario
    Hi David - let' start with the plug # just to be certain of the correct plug - my Parts Manual revised 2017 version shows an NGK 1ZFR7M . but I believe a discussion on here was that a supplement for gen 2 showed a 1zfr5g was correct - the 5 is supposed to be 2 ranges hotter . I can only confirm what my revised parts manual shows - 7m.
    On the Service Manual of February 2001 so it' gen 1 shows NGK -PZFR5F-11 . Heavy Duty - gapped at 40 So this is all the info I have available other than calling merc tech , but i suspect the call should be made to ascertain the correct info on the subject.
    I did not recieve a supplement with my ServiceManual . So there may be more to the story and the thread on here may be correct - but sometimes things get mixed up in translation and it got crossed up . Remember my pats manual is up to date but a supplement may still Trump that . Doubtful though since it' 2017 . Let' see if we can stir a Master Tech up for an answer-
    Western Pennsylvania
    How many hours on engine? When I had a 300XS I had the injectors(fuel/air) cleaned at about 180hrs because plugs were way blacker than yours. Also had some buildup on top of pistons. But overall if it runs good be happy!
    90 21Skater w/300xs - sold
    98 STV Euroski w/280 - sold
  4. Likes XstreamVking liked this post
    Sep 2017
    ontario
    David , had mine on a stand and pulled a plug for your reference and was 7M . Burn on #2 showed dark brown visual on open side and carbon dark on rest of plug surround . Rememer this would have been an idle , cool run into dock . This plug #2 was as expected - i thought anyway - when I fog I will have a more consistent finding for you to compare to . So anyonr have this supplement to the manual Stating different plug ?
    Apr 2017
    Pomona ny
    Should get injectors serviced as well. I get mine done before every season and a few of the air injectors are caked with carbon build up
    Maybe 20 hours on the engine
    Sep 2017
    ontario
    David - I went to fog the motor and only got 1 bank of plugs done and all looking similar , ceramic is a nice dark brown in phases it seems . White areas then back to a dkbrown in a pattern **** the darkest at back of elective opening . I will be certain of the other bank tomorrow - when I get another can to finish up . You didn' by chance introduce a break in again - delivering an oil rich delivery? Or I suspect you putted around a bunch before putting away last run since it' a tad chilly . You have not stated the plug but suspect 7m
  9. #8
    When I had my 300xs, was told not to fog the engine because could foul the injectors. not sure if it's changed?
  10. #9
    Sep 2017
    ontario
    I thought it was a good thing for the bore and rings ,but now you got me thinking . Can anyone else confirm this statement . Thanks for bringing that forward .
  11. #10
    Feb 2014
    Missouri
    Dark plugs are normal for an opti on 91. They only run 90-110psi compression for an average. Lots of soot and carbon from running water cooled fuel into 110 compression.
    Try to find a low rvp fuel as standard v-grade and a-grade is close to 10rvp look for 8 or less. I’ve been splashing vp4sse to cut rvp
    Ohm the plug from end to tip if only a small spot is 5000 ohm they’re do for a clean or replacement.
    Honestly were here supposed to replace the crush rings each time you pull it out to see them.
    I find more broken in the nut then fouled. But a batch of weak 91 can black them um good
    Run some pea type cleaner to keep them clean.
    As for fogging i dont think it hurts. But merc doesn’t recommend it. They squirt dfi in the spark hole and manualy rotate the engine to oil the rings and bore. I use a spray bottle myself just for a finer mist.
  12. #11
    My mechanic says don't worry. Idles well, runs hard at top end, relax
  13. #12
    Aug 2012
    Tenkiller Lake, OK
    That is a normal plug for an Opti. Remember it is a 2 stroke. The tip is brown = good burn.
  1. Mercury Tech: 1993 2.5 black spark plugs
    By redsnapper386 in forum Technical Discussion
    Last Post: 03-12-2017, 03:14 PM
  2. Mercury Tech: ave gas spark plugs
    By R.grover in forum Technical Discussion
    Last Post: 07-28-2010, 09:10 PM
  3. spark plugs
    By bildit4u in forum Technical Discussion
    Last Post: 06-21-2010, 09:04 PM
