Results 1 to 5 of 5
Thread: 300xs power head on a 300x mid
10-24-2019, 04:59 AM #1Member
- Mar 2017
- central fl
- 95
Has anyone done it?
10-24-2019, 05:58 AM #2
sure you just need an exhaust plate for opti or you gotta drill some holes in the x plate for compressor fittings.
10-24-2019, 06:34 AM #3
Yes, bolts on 300x adapter. Remove large pipe plug on left side of adapter and plumb the water line to the air compressor there. Air rail dump can go just about anywhere. Trim cowl liner if using 300x cowl. Be ready to save gas and go slower.
10-24-2019, 07:25 AM #4Member
- Mar 2017
- central fl
- 95
Thanks for the replies. I like to save gas and at my age everything is slower.
kct11 liked this post
10-24-2019, 08:00 AM #5Supporting Member
- Apr 2003
- New Smyrna Beach, FL./LOTO
- 6,647
- 608
- 924
- 1700
- 7160
- 3 Post(s)
You can also modify the X cowl to clear the compressor and have it retain a stock appearance without loosing the rear water catch. I have one of each and unless I cover the power head when trailering a on a road trip, it draws a lot of trash in the open cowl. Fuel use is almost 1/2 with an XS but you miss the twist up top.
300xs power head on 300x mid
By RDL in forum Technical DiscussionReplies: 13Last Post: 01-17-2019, 07:16 PM -
Wtb 300x power head
By ult680 in forum Outboard EnginesReplies: 5Last Post: 02-04-2016, 09:27 PM -
Can you swap a 300xs power head onto a 300x mid?
By ct20sutphen in forum Technical DiscussionReplies: 0Last Post: 01-06-2012, 02:36 PM -
Which makes more power 300x or 300xs
By Liberator*21 in forum Technical DiscussionReplies: 19Last Post: 12-08-2010, 08:52 PM -
Mercury Tech: 300xs power head painted black??
By kct11 in forum Technical DiscussionReplies: 1Last Post: 07-26-2008, 05:22 AM
