Results 1 to 5 of 5
    Dec 2017
    Lake Ashby, New Smyrna Beach FL
    Lower Unit gear ratio question-
    If a l/u has a 1.75:1 ratio is the engine crankshaft turning 1.75 times for each turn of the prop shaft or is it the other way around?
    Dec 2017
    Never mind. Found it. Thanks
    About a Year ago this was a Topic on a post. Heres my Response on Gear ratios.
    Matt back in July last year you posted this. https://www.screamandfly.com/showthr...er+Gear+ratios My response was post#5. And here was my response.
    There are 4 lower merc gear ratios.
    2:1, 1.87:1, 1.75:1, 1.62:1.
    It works like this:
    2:1 is two engine rotations to one Prop rotation
    1.87:1 is 1 7/8 engine rotation to one prop rotation
    1.75:1 is 1 3/4 engine rotation to one prop rotation
    1.62:1 is 1 9/16 engine rotation to one prop rotation
    In theory heres the difference, and Ill use 5000 RPM and a 26 pitch prop as a base line for the example.
    The formula to calculate Theoretical speed is:
    RPM X Pitch =
    Ratio X 1056 =
    2:1
    5000 x 26 = 130000 = 61.5 MPH @ 0% slip
    2 x 1056 = 2112
    1.87:1
    5000 x 26 = 130000 = 65.83 MPH @ 0% slip
    1.87 x 1056 = 1974.72
    1.75:1
    5000 x 26 = 130000 = 70.34 MPH @ 0% slip
    1.75 x 1056 = 1848
    1.62:1
    5000 x 26 = 130000 = 75.99 MPH @ 0% slip
    1.62 x 1056 = 1710.72
    So as you can see in theory by using 5000 RPM and 26 Pitch as a Base line the different ratios show around a 5 MPH difference. Now many variables come into play here, Boats weight, Can the motor carry the same pitch prop all the way through its maximum RPM range?
    Now lets look at it a different way changing only prop pitch by 2 (ex 24 P vs 26 P) for this example ill use 1.87:1 as the base because as shown in the theory above the different ratios equate to around 5 MPH.
    5000 x 26 = 130000 =65.83 MPH @ 0% slip
    5000 x 24 = 120000 =60.76 MPH @ 0% slip
    As you can see by merely changing the prop by 2 pitch sizes the MPH difference is almost the same @ 5 MPH difference.
    Again many variables come into play and the above is based on Theory not real world results.
    Also the tighter gearratios while providing a faster top end speed will also show a more sluggish hole shot.
  4. Likes tunnelmike liked this post
    Feb 2005
    Muskoka Canada
    Gear ratios directly effect the torque a propellor sees. To simplify if a motor makes 100 ft lbs of torque and you have a 1:1 ratio you see 100 ft/lbs applied
    to the prop shaft. Same motor with 2:1 will double the torque, but at half the shaft speed.
    This is over simplified. In other words, regardless of prop in our typical application a short ratio will have a peakier or quicker acceleration and the taller ratios will have a longer more stable pull
    2023 TUFF 25
  6. Likes Jimboat, 90 5.0 liked this post
    Quote Originally Posted by RBT View Post
    AMEN.... Torque multiplication makes a whole variable...
  8. Likes 90 5.0 liked this post
  1. lower unit gear ratio
    By duke_snyder in forum Technical Discussion
    Last Post: 12-11-2011, 09:54 AM
  2. merc Lower unit gear ratio
    By rmpenton1 in forum Technical Discussion
    Last Post: 03-29-2010, 05:13 AM
  3. Lower Unit Gear Ratio!
    By Reddawgzulu in forum Technical Discussion
    Last Post: 09-15-2006, 05:27 PM
  4. lower unit / gear ratio ?
    By live2ride31 in forum Technical Discussion
    Last Post: 08-21-2006, 12:38 AM
  5. Lower Unit gear ratio
    By CNT in forum Technical Discussion
    Last Post: 09-02-2003, 03:10 PM
