Results 1 to 3 of 3
Thread: Epoxy Goof Up
    Jun 2004
    long island
    Epoxy Goof Up
    I goofed on a batch of West Epoxy the other day.
    I believe I mixed all hardener and no resin
    After 1000's of mixes I cant believe it so, but I was dead tired
    I thought it looked thin when I applied it
    Luckily it was mixed with fillers in a plywood block lamination and not a big glass layup
    The question is can I scrape off all of the mixture & clean with Acetone / Xylene and relaminate the wood?
    or is it F****?
    I'm concerned about the pure hardener that soaked into the end grain
    The plywood block fabrication was a fairly complicated endeavor and I'd rather reuse it
    Thanks for any insight!
    Dec 2006
    Mt. Laurel, N.J.
    The correct mixture will be brittle at the point of contact with the wood
    Azure AZ259, 8.1
    Jun 2004
    long island
    That’s what I was thinking
    thanks!
  1. Goof off on Fiberglass
    By ActivatedSludge in forum Fiberglass and Composites Discussion
    Last Post: 03-07-2012, 10:16 AM
  2. Glastron transom ? I want to make sure I don't goof it up now
    By ssv1761982 in forum Fiberglass and Composites Discussion
    Last Post: 08-19-2010, 05:36 PM
  3. Best epoxy?
    By Waterdigger in forum Technical Discussion
    Last Post: 08-28-2007, 07:05 PM
  4. epoxy?
    By Sutphen115 in forum Fiberglass and Composites Discussion
    Last Post: 07-07-2005, 05:32 PM
  5. epoxy
    By Riverratt in forum Technical Discussion
    Last Post: 03-24-2004, 09:59 PM
