Results 1 to 15 of 23
    May 2002
    Harriman, TN
    How do I press this hub out of my prop?
Name:	Flo-Torq SSR HD.png
ID:	451195It went in easy enough but it doesn't want to come out now.
  2. Likes revlimiter, Glasstream15 liked this post
    Dec 2006
    Mt. Laurel, N.J.
    Bfh
    Azure AZ259, 8.1
  4. Likes B.loco60 liked this post
  5. #3
    #2 iron from the Mayo clinic, Fla. / Blue Ridge, VA.
    take it to a propshop that does it every day and get some lunch
    most overnite successes usually take at least 10 years
    Certified turd polisher,
  6. Thanks ssv1761982 thanked for this post
  7. #4
    I've got a 6"x 6" block of wood about a foot long that I hole sawed about a 3" hole down as far as the saw would reach .. about 2 - 2.5" deep. I chizeled out the center plug and I use the block to rest props in while I press hubs in and out. The hub only needs to move about an inch before I hear it fall into the "basket".
  8. Thanks ssv1761982 thanked for this post
    Likes ssv1761982, Glasstream15 liked this post
  9. #5
    I use the E-Z shift ( or whatever they call the new ones) hubs like the one in post # 1.
  10. #6
    Aug 2015
    Southeast
    I use a bottle jack, socket, and a couple short 2x4s underneath the boat trailer. Prop shop or the bushing tool above would be better. These hubs are called SSR I believe. I quit using since it was such a pia to get them out.
    STV ProComp w/ 225 Promax
    STV Procomp with 280
    25 Liberator "The Battleship"
    Blazer 650 Pro Tour
  11. Thanks ssv1761982 thanked for this post
    Likes ssv1761982 liked this post
  12. #7
    tenn
    Let us know how it goes, looks like a bear to press out without hurting something.
  13. #8
    Oct 2017
    Hugo, MN
    I use the rubber Rubex hubs. To get them out I've stuck the prop in the freezer for a while to shrink the rubber hub. Then pound it out.
  14. Likes ssv1761982 liked this post
  15. #9
    Dec 2010
    Knoxville, TN
    or stop by the shop when you're up this way and I'll have it out ina minute while you wait...
  16. Thanks ssv1761982 thanked for this post
  17. #10
    Aug 2005
    Knoxville , TN
    Quote Originally Posted by JoJo10 View Post
    Thank you sir!
    1995 Allison XB-2003, 225 Promax
    2002 Trans Am, pulls the boat fine.
  18. Likes ssv1761982 liked this post
  19. #11
    Lake Coochiching, Ontario
    I bought a second SSR hub for a second prop. Seemed easier than getting the first one out of the Trophy. The second is stuck in a drag 4.
  20. #12
    May 2002
    Harriman, TN
    Quote Originally Posted by David View Post
    Joe at East Tennessee Prop pressed it out for me. I wanted to run it on my small shaft lower so it had to come out. I think I will stick with the solid hubs from now on.
  21. #13
    Jul 2011
    Gloucester, VA
    That hub doesn't need to be "pressed" out. They are just tight amd get stuck. An appropriately sized socket, a soft faced dead blow hammer, and a sturdy surface will make easy work of it.
  22. #14
    they don't get damaged coming out?
  23. #15
    Jul 2011
    Gloucester, VA
    No. It a flo-torq style. Not a press in. They just get hung up
  1. Formula One PROP press release
    By Wayne Worthy in forum Racer's Hangout
    Last Post: 04-27-2010, 12:34 PM
  2. Press "1" if you want to be an American. Press "2" if you want to go home.
    By Capt.Insane-o in forum The Scream And Fly Lounge
    Last Post: 01-23-2009, 10:32 PM
  3. where to buy a press??
    By wing nut in forum General Boating Discussion
    Last Post: 01-26-2004, 07:01 PM
  4. Water Press and Fuel Press guages
    By signpro in forum Technical Discussion
    Last Post: 08-22-2002, 01:18 PM
