Results 1 to 15 of 40
10-20-2019, 11:49 AM #15000 RPM
- Nov 2008
- martinsburg, wv
- 398
New to mercs - what exactly do I have here?
Hey guys, took a boat on a trade and it has a merc/mariner motor on it. Serial number for transom bracket is 6637220 - 150 hp.
The intake manifold has the number 969-9078-c1. The heads are 18787-c2 for both. Carburetors are wh-39-1,2,3 with the top and bottom being 1626 and the middle 1346.
What exactly do I have here? Is it a 2.0, 2.4, 2.5 block? Is this thing safe to run with the jumble assortment of parts? Approx year and true horsepower? Thanks so much!
10-20-2019, 12:06 PM #2
Old 2.0
They are good motors.Azure AZ259, 8.1
10-20-2019, 12:11 PM #35000 RPM
- Nov 2008
- martinsburg, wv
- 398
If it has been bored over before, will the pistons be stamped with the oversize amount?
10-20-2019, 12:42 PM #45000 RPM
- Nov 2008
- martinsburg, wv
- 398
To add - not sure if its pertinent info, but the bore on all 6 is 3.375" +/- .001 according to my digital caliper
10-20-2019, 12:43 PM #5
Mercury Piston Standard 2.0L Bore Size is 3.125
Azure AZ259, 8.1
10-20-2019, 12:45 PM #6
Mercury Piston Standard 2.5L Bore Size is 3.5"
Azure AZ259, 8.1
10-20-2019, 12:46 PM #7
Mercury Piston Standard 2.4L Bore Size is 3.377
Azure AZ259, 8.1
10-20-2019, 12:47 PM #8
Take several pictures of the intake manifold behind the carbs.
Also put a magnet on the cylinder and see if it sticks.Azure AZ259, 8.1
10-20-2019, 12:58 PM #95000 RPM
- Nov 2008
- martinsburg, wv
- 398
All 6 are 3.375" and a magnet does not stick.
10-20-2019, 12:59 PM #105000 RPM
- Nov 2008
- martinsburg, wv
- 398
10-20-2019, 01:04 PM #11
It's a 2.4 liter 175 or 200hp with late model one peice heads.
Azure AZ259, 8.1
10-20-2019, 01:35 PM #12
1985 2.0 150 ELPTO sold in 1987 per serial number given
10-20-2019, 02:12 PM #135000 RPM
- Nov 2008
- martinsburg, wv
- 398
10-20-2019, 02:46 PM #14
6637220 Even starter has manufacture date on 1985
10-20-2019, 03:10 PM #15
I'd say chrome bore 200. It has 200 on welch plug. I had 2 ,2.4 200 with that 200 on plug,, also the air box is fir 200 also , the 150 had diff air box
But then again a vertical 150 clam shell wont fit horiz 200 without mods. Does it have turnbuckle latches? Or 1 big one in front?Last edited by Merc 2.5; 10-20-2019 at 03:12 PM.
RH & LH 200 Mercs
By rjw158 in forum Outboard EnginesReplies: 19Last Post: 05-26-2018, 07:56 AM -
EFI Mercs
By skiwi in forum Engines WantedReplies: 0Last Post: 06-13-2017, 01:26 PM -
Mercury Tech: 280 mercs
By fatboy0484 in forum Technical DiscussionReplies: 9Last Post: 01-12-2011, 07:23 PM -
New mercs
By Ronny Jetmore in forum General Boating DiscussionReplies: 13Last Post: 03-04-2010, 11:18 AM -
BP Mercs
By ironlake2 in forum Outboard and Racing HistoryReplies: 1Last Post: 10-26-2009, 10:19 PM
