Results 16 to 30 of 31
Thread: 300XS bore scuffing
10-17-2019, 08:58 AM #16Junior Member
- Jul 2012
- N/A
- 29
I felt the ports of a blown 190 hour 225 optimax block that was laying at a dealer, they are wayyy smother then mine and the cross hatching is much more visible then my 60 hour motor. I doubt that its an oiling issue as all roller bearings are drenched in oil.
10-17-2019, 09:10 AM #17Screaming And Flying!
- 14,753
- 381
- 1305
- 5602
- 11033
I would trust chaz's opinion 100% myself. Seems to trace the damage to the most likely cause.
10-17-2019, 10:48 AM #185000 RPM
- Nov 2009
- hardyville va
- 367
- 7
- 38
- 43
10-17-2019, 03:32 PM #19
10-17-2019, 03:58 PM #206000 RPM
- Feb 2011
- HUDSON, FLORIDA
- 1,528
- 433
- 64
- 435
- 452
10-17-2019, 09:14 PM #21
The motors that say "racing" on them usually get pulled off the line and go thru a little extra hand grinding / sanding before they get put together. Yours looks like it got pulled off the line and was never finished.
The left side transfer has a chamfer , but the corner also has a hook that never got blended. Right side, which was obviously making metal is hard to see the bottom. And like I said , top-front looks to have tiny chips broken out of the corner .. might be the pic, could be my eyes. The exhaust port floor does look very sharp, and the ring has been cutting away at the right side corner.
Mercury wty ... Sir, why did you take the heads off yourself ??? If you felt you had a problem with your motor you should have taken it to one of our dealers ???
Ane even then, if it aint broke .. they got no reason to fix it.
You can try, they will have a rep come look at it ............
If he say's yes it's a developing problem, they will either put a new or remanned powerhead on. Whichever that still have in stock. if he says no. Get his boss's phone number. Two or three of those ... and they will replace it.
If they play the "you took the heads off card" you can (*&^^*(%$ them for a while. We already know that they are (*&$%*()(*%% &&^$$*(() So you will be preaching to the choir .. The easiest thing to do at that point is to just slip it apart and prep it like it's yours instead of flying down a conveyor belt ...
Dave Strong, tux974 liked this post
10-17-2019, 09:33 PM #22
Chaz you looked at them pictures way closer than I did. Good call on the piss poor port finishing. Guess I shouldn't be on my phone driving home from moms house. the rest of what your saying about self diagnosing stuff under warranty is so true.
10-18-2019, 05:08 AM #23
Dave Strong liked this post
10-18-2019, 07:36 AM #245000 RPM
- Nov 2009
- hardyville va
- 367
- 7
- 38
- 43
Just a guess. If the key has been touched with a running motor or bendix is slow to engage, hard metal is made rite where the intake horn is. Not scuffing, scratches. It's hard to believe Mercury racing, a cut above normal production would send out a high dollar piece with such a flaw.
10-18-2019, 08:03 AM #25Screaming And Flying!
- 14,753
- 381
- 1305
- 5602
- 11033
Any thing coming into the intake would have to not get stuck in the oil coated plenum, then make it past the oil soaked reeds, past the oil drenched crankcase into the bores.
Merc 2.5 liked this post
10-18-2019, 10:34 AM #261980 Cougar 19 tunnel,90 2.4L Bridgeport EFI in middle of restoration.
10-18-2019, 11:22 AM #27
10-18-2019, 01:15 PM #28Screaming And Flying!
- Jul 2002
- FT WORTH, TEXAS
- 8,031
- 9
- 146
- 313
- 503
i think lack of champering caused your motor to manufacture the grit that scored the cylinders ! when rebuilding the grit comes from every where in machining also from sealing rings that need be removed and grooves cleaned out, reed plates are a big culprit of getting stuff inside,it just looks not finished in MHOP. down here in Texas we have a big problem with dirt dobbers building their nest inside of cowlings the nest are mud when they are building them but when next year rolls around the boat owner who never checks anything except gas gauge have the now dirt nest coming loose falling into bottom cowl and being pulverized into dust by motor vibration and being sucked into engine and before long its really toast ive seen them so bad that all cross hatch is gone and big wear on crank journals rod caps basically everything inside motor is junk
ChrisCarsonMarine thanked for this postChrisCarsonMarine, tux974 liked this post
10-18-2019, 06:11 PM #29Screaming And Flying!
- Dec 2001
- 9,502
- 271
- 191
- 1976
Yes on the Dobbies..... and some reed chips ?
10-19-2019, 05:12 AM #30
I do agree from pictures the ports look sharp.
After machining especially a used block finding that fine debris stuck to oil behind ports common. Hence the dumping methods multiple times with clean soapie warm water works.
IMPO properly cleaning plenum, VST, injectors, intake, reeds etc is important in a fresh rebuild.
I have seen were guys just take a motor apart put parts in totes and just bolt things back together when block is ready without cleaning or properly inspecting each and every part or wiring.
TEXAS20225, Dave Strong liked this post
Merc small bore to big bore carb replacement and jetting question
By hollywood120 in forum Technical DiscussionReplies: 1Last Post: 06-09-2019, 08:47 AM -
280 Piston Scuffing
By bec in forum Technical DiscussionReplies: 30Last Post: 10-08-2007, 09:38 AM -
HELP! 2.4 Bridgeport Carb 2nd time scuffing #5 cylinder
By Shmitee in forum Technical DiscussionReplies: 3Last Post: 04-29-2001, 09:22 AM
