Results 16 to 27 of 27
Thread: Electronic Ignition Conversation
10-17-2019, 04:36 AM #16
"CC" means 150 block. The "1" is month made. "13" should be year, but that is not a 2013 motor.
10-17-2019, 06:33 AM #17
Yep. Cc is usually 150 xr6. If memory serves correct Ur mota is a 96. Ur mid look like 01 xr6. 2-5-96 is build date
DEN thanked for this post
10-17-2019, 04:09 PM #185000 RPM
- May 2011
- Oklahoma City, Ok
- 237
- 46
- 12
What IS the powerhead then? 150 what? a 1996 XR6? any way to tell what model powerhead this is?
Nada lists 7 1996 merc 150HP that year, including a XR6. All the EFI's can be thrown out the window, leaving 4 to choose from.
I have no idea even to guess. But I'm sure their are some differences with the 4 models to choose from.
Most likely, all use the same parts with maybe different internals. (?) Serial # does me no good to research the powerhead.
Would be nice to know for sure tho.
If you think this is fun, wait til next weekend!
10-17-2019, 04:14 PM #19
10-17-2019, 05:10 PM #205000 RPM
- May 2011
- Oklahoma City, Ok
- 237
- 46
- 12
yes,, mine has the same plug same place, BUT there are no numbers or markings on mine.
so mine is a 96 XR6?If you think this is fun, wait til next weekend!
10-17-2019, 05:30 PM #21
I do. Believe cc block was xr6 150. Not 100% but 90. Theres a serial behind throttle arm where 2 block halves meet runnin vertical. Unless it's a replacement block. On those sum didnt have #s
10-17-2019, 06:14 PM #225000 RPM
- May 2011
- Oklahoma City, Ok
- 237
- 46
- 12
Theres a serial behind throttle arm where 2 block halves meet runnin verticalIf you think this is fun, wait til next weekend!
10-18-2019, 04:07 AM #23
Im not sure what you are trying to figure out. Your motor is a "mixed bag". Very obvious that it has a promax divider plate. Its nearly impossible to tell exactly what you have from the outside. Most parts are interchangeable on 2.0, 2.4 and 2.5 motors. Your motor could be a 2.0 or 2.5.
10-18-2019, 05:11 AM #24
The stock ignition is good for over 300 hp and 10k RPM. Look elsewhere for modifications...
powerabout liked this post
10-18-2019, 05:33 AM #25
10-27-2019, 12:33 PM #265000 RPM
- May 2011
- Oklahoma City, Ok
- 237
- 46
- 12
Hey guys, Sorry for the late reply here. I just got back from Japan, work related.
I do thank each and everyone of you whom cleared up my confusion here.
David>>>>>If you think this is fun, wait til next weekend!
11-25-2019, 10:23 PM #275000 RPM
- May 2011
- Oklahoma City, Ok
- 237
- 46
- 12
Build date 2-5-96 which is stamp on the block. "CC" is the stamp code for and 150hp XR6. so with this confirmed information, I have concluded the serial #s 0G303046 thru 0G760299
At least now a can get parts when needed and should not have to worried if they will fix or not.
Thanks again for all y'all help!
Also a huge thanks to Mach351, here @ S & F.Last edited by DEN; 11-25-2019 at 10:25 PM. Reason: typo
Mercury Tech: Electronic ignition HELP needed please...
By Iwanngofast in forum Technical DiscussionReplies: 0Last Post: 07-03-2014, 03:26 PM -
Problem with electronic ignition(pertronix)
By mdsv16 in forum Technical DiscussionReplies: 7Last Post: 05-12-2013, 01:19 PM -
Problem with electronic ignition ( pertronix)
By mdsv16 in forum Electronics, Audio Systems, and WiringReplies: 0Last Post: 06-11-2008, 08:04 PM -
Electronic Ignition
By JTS Racing in forum Technical DiscussionReplies: 2Last Post: 11-11-2001, 10:26 AM
