Results 1 to 15 of 27
    May 2011
    Oklahoma City, Ok
    Electronic Ignition Conversation
    Over this past weekend, I pick up a 2001 150 Promax XR6.
    With all the mods out there today, I would think there is a
    mod for electronic ignition conversation for this OB.
    After searching around, I'm more confused!
    I'm I dreaming or is this possible?
    Thanks in "Advance"
    If you think this is fun, wait til next weekend!
    Sep 2017
    Ashland city tn
    A 150 promax or a 150 xr6?
    Apr 2017
    pa
    5 Post(s)
    It has points and a distributor? Im confused also
    Quote Originally Posted by bullet123 View Post
    Pictures needed.
    Jan 2003
    aalsmeer
    I, m interested to!
    I never had a conversation with my ignition system ��
    Apr 2017
    pa
    5 Post(s)
    A promax should be efi with an ecu. xr6 would be carb motor. both should have trigger, stator and switchboxes for ignition, which is a type of electronic ignition. Around the year 2000 mercury went to a cdm ignition, which does not use switchboxes if that is what you mean.
  7. Likes Merc 2.5 liked this post
    Quote Originally Posted by PanRonnie View Post
    I, m interested to!
    I never had a conversation with my ignition system 🤔
    Do you need an introduction ... to break the ice .. ???
  9. #8
    May 2011
    Oklahoma City, Ok
    Ok guys, I am REALLY confused, but I'm thinking its my ignorance on the subject.
    Some background:
    I put an MSD box with an trigger wheel/magnet pickup on a subaru engine a few years back.
    I gutted the distributor except for the rotor inside. The distributor/rotor was used ONLY for spark delivery. worked very well.
    This is the idea I was going for in this OB I just brought. I have no idea HOW spark gets to the plugs before the coils packs, and when the motors rpm rises, the spark
    must be faster. Not sure how this happens. On the subaru, the trigger wheel that spins with the crank shaft did this. On an OB, it cant be to far from that idea.
    Your question: Pic of my ID plate said XR6. (I thought an XR6 WAS a Promax, I'm I wrong here?)
    I understand "trigger, stator are.
    What are "switchboxes?"
    What is CDM ignition.
    Please explain?
    I am ALL ears @ this point.
    Thanks for all your replys
    This rookie going to move up some day!
ID:	450880 Click image for larger version.
ID:	450881 Click image for larger version.
ID:	450882 Click image for larger version.
ID:	450883Click image for larger version.
ID:	450884Click image for larger version.
ID:	450885Click image for larger version.
    Last edited by DEN; 10-16-2019 at 05:00 PM. Reason: reload pics, hate when pics are on there sides
  10. #9
    Sep 2017
    Ashland city tn
    Gonna need the #s behind throttle arm or Welch plug on top block. looks like freeze out plug. U got a frankinmerc. Which is fine just need #s off powerhead
  11. Likes Glasstream15 liked this post
    Sep 2017
    Ashland city tn
    And 5 or 6 yrs difference in mid and powerhead. I can see date on block just not serial
    Apr 2017
    pa
    5 Post(s)
    Xr6 stump, the rest is a mongoloid. Does it have 2 different heads?
  14. #12
    Sep 2017
    Ashland city tn
    Hard to guess cause 01 xr6 would b diff , so u have a promax cowl (diff mota) xr6 mid , ?powerhead
  15. #13
    MIAMI FLORIDA
    Distributors and water don't play well together, outboards have been distributor-less for 40yrs.. , the system you have is electronic and much better than what you had on the Subaru for this application since it doesn't require a battery to run and is pretty much water proof..
  16. #14
    May 2011
    Oklahoma City, Ok
    Im sure yall can see these #'s just forward of the throttle arm @ the top. "2596" what does this # mean?
    In the pic, just behind the thottle to the left off the above #'s is CC 1 13....looks like there was a space between the 1's on purpose.
    Only #'s I found on throttle side.
    Both heads look identical.
    What do these numbers mean?
    Im now good with the ignition thing........I wont touch it now.
  17. #15
    Jan 2003
    aalsmeer
    Enjoy!
    Attached Thumbnails Attached Thumbnails MERCURY__2.4L__2.5L__3.0L_V6_EFI_Tehnicheskoe_ustroystvo_dvigateley(1).pdf
  18. Likes bullet123 liked this post
  1. Mercury Tech: Electronic ignition HELP needed please...
    By Iwanngofast in forum Technical Discussion
    Last Post: 07-03-2014, 03:26 PM
  2. Problem with electronic ignition(pertronix)
    By mdsv16 in forum Technical Discussion
    Last Post: 05-12-2013, 01:19 PM
  3. Problem with electronic ignition ( pertronix)
    By mdsv16 in forum Electronics, Audio Systems, and Wiring
    Last Post: 06-11-2008, 08:04 PM
  4. Electronic Ignition
    By JTS Racing in forum Technical Discussion
    Last Post: 11-11-2001, 10:26 AM
