Results 1 to 10 of 10
10-13-2019, 05:21 PM #1Junior Member
- Jun 2019
- Miami
96 mariner 225 carb idling at 2-3k rpm
At first I thought I had a fuel problem cuz I had to be squeezing the bulb to keep the motor running so I replaced the fuel pump and a few lines that were dry rotted n right after that after numerous times trying to start the motor n finally started it, it went straight to 3k rpm at idle.. I took apart the carb n found a line wit a bolt in it in the Reed cage. Dont kno how that got in there maybe previous owner. Put everything back together and same thing idle at 3k.. bought a carb rebuilt kit slap it on n same thing idk wat else to look for n need some help thanks
10-13-2019, 05:30 PM #2
Need back down idle timin. Can u take a pic port side mota?
10-13-2019, 07:01 PM #3
look for air leak too
22R
10-14-2019, 01:06 PM #4Screaming And Flying!
- Jul 2002
- FT WORTH, TEXAS
- 8,031
- 9
- 146
- 313
- 503
this is 3.0 right
10-15-2019, 12:38 AM #5Junior Member
- Jun 2019
- Miami
Yes it's a 3.0 I'll get some pics some time this week cuz boat is at the keys. crazy part is that the boat waz running perfect n now I just cant figure it out smh
10-15-2019, 08:30 AM #6Junior Member
- Oct 2019
- East Granby, Connecticut
- 14
- 21
Did you test/replace high pressure pump and pulse pump?
Can you put a fuel pressure gauge on to verify?
There is a small screen inside fuel center on those I think, maybe its clogged?
Does primer ball go flat?
Check all vacuum lines also.
If that all checks out time to start on electrical side I guess...tps, map, cam sensor etc ..
But sounds like a fuel issue to me.
10-15-2019, 04:44 PM #7
10-16-2019, 07:10 AM #8Junior Member
- Oct 2019
- 14
- 21
10-16-2019, 07:31 AM #9
I do it to sometimes. Chit happens
10-16-2019, 03:48 PM #10
OK .. you two .. there's still a little matter of a cam sensor ...
55 Mariner 2cyl carb
By fasterbass in forum Parts WantedReplies: 0Last Post: 01-27-2015, 06:56 PM -
Idling and carb problems need help!!!!
By rideordie in forum Technical DiscussionReplies: 2Last Post: 05-09-2011, 11:33 AM -
Wot stumble 200 mariner (carb)
By Mariner245 in forum Technical DiscussionReplies: 5Last Post: 07-11-2009, 11:15 AM -
mariner 225 2.4 carb
By xtreme53 in forum Technical DiscussionReplies: 5Last Post: 08-15-2002, 07:23 AM
