Results 1 to 15 of 20
Thread: Paramount
10-13-2019, 03:32 PM #1Junior Member
- Sep 2013
- North palm fl
Paramount
Can you get a paramount to touch 80 without hull mods
10-13-2019, 04:04 PM #2The Historic Photo Master
- Jan 2004
- Florida
- 37,836
- 64
- 1667
- 337
- 19218
- 3 Post(s)
definitely. if your tow vehicle can pull it that fast, no problem...
mach351 liked this post
10-13-2019, 04:14 PM #35000 RPM
- Mar 2017
- Miami, FL
- 358
- 10
- 47
With a 450r it should be easy
Jeeper thanked for this post
10-13-2019, 05:12 PM #4Junior Member
- Sep 2013
- North palm fl
. Thanks
10-13-2019, 05:27 PM #5
I would think If you blueprinted the rear with an 300R you should get to 80, with out T top.
10-14-2019, 02:02 PM #65000 RPM
- Mar 2017
- Miami, FL
- 358
- 10
- 47
You need a lot of setback if you want to go fast. Once you get to a certain speed, so much of the boat is out of the water that the wedge really doesn't matter. A 300 opti will get you there
10-14-2019, 02:21 PM #7We have invented the world; WE see
10-14-2019, 04:22 PM #8
10-14-2019, 07:22 PM #9Junior Member
- Sep 2013
- North palm fl
Thanks so much makes sense to me I know they have hook built in just have to straight edge it see how much work to fix or not
10-14-2019, 08:51 PM #10
working on the bottom is easy when boats is flipped over.
10-15-2019, 03:31 PM #11The Historic Photo Master
- Jan 2004
- Florida
- 37,836
- 64
- 1667
- 337
- 19218
- 3 Post(s)
its quite a bit different than just sanding a hook out, on the paramount. you cant change what daryl intentionaly designed onto(added) an existing bottom design, in an attempt to alter the boats existing performance, into a full time bow down performance boat, which he accomplished. it was not what he originally had in mind, but that's the way it ended up getting molded. it turned out to be a very nice, dry, little, 21 footer, that was affordable & looked kinda racy for a cc. the rather large, partial pad bottom wedge, is nothing that can be "removed", or improved upon, without major surgery, which just isn't practical to do. the much better option, if blistering speed is the objective, is to locate & buy one of the original boats that the paramount was copied from. the action marine 21 center console. looks identical other than the keel area.
XstreamVking, JBS liked this post
10-15-2019, 11:31 PM #12
I've had mine at 70mph so far with no hull mods, but motor had issues and havent messed with setup or props. Only had a 23 pitch on it. Hopefully when the motors fixed and I play with setback it should be into the 80s. I'm running a 350 verado
10-16-2019, 08:21 AM #13
Im amazed at how well that hull holds the weight of that 350 Verado. What is the beam on the Paramounts?
10-16-2019, 08:56 AM #145000 RPM
- Mar 2017
- Miami, FL
- 358
- 10
- 47
capteliminator thanked for this post
10-16-2019, 06:42 PM #15The Historic Photo Master
- Jan 2004
- Florida
- 37,836
- 64
- 1667
- 337
- 19218
- 3 Post(s)
They are a small 21. As they were originally tooled using a shorter boat, a 19', which was/is commonly done. The beam is 86'' at the widest point. They are not a self-bailing boat.
WTB: Paramount 21
By sp543 in forum Hulls WantedReplies: 5Last Post: 05-06-2021, 12:14 PM -
WTT for a 21 or 26' Paramount
By lvnspeed in forum Hulls larger than 20'Replies: 0Last Post: 08-13-2018, 11:10 AM -
21 Paramount
By paramount paul in forum Hulls larger than 20'Replies: 0Last Post: 08-18-2015, 03:45 PM
