Results 1 to 15 of 20
Thread: Paramount
    Sep 2013
    North palm fl
    Lightbulb Paramount
    Can you get a paramount to touch 80 without hull mods
    definitely. if your tow vehicle can pull it that fast, no problem...
  3. Likes mach351 liked this post
    Mar 2017
    Miami, FL
    With a 450r it should be easy
  5. Thanks Jeeper thanked for this post
    Sep 2013
    North palm fl
    ������������. Thanks
    PARADISE /Naples
    I would think If you blueprinted the rear with an 300R you should get to 80, with out T top.
    We have invented the world WE see
    Mar 2017
    Miami, FL
    You need a lot of setback if you want to go fast. Once you get to a certain speed, so much of the boat is out of the water that the wedge really doesn't matter. A 300 opti will get you there
    PARADISE /Naples
    Mar 2015
    bunnell FL/old town FL
ID:	450721This one in south Fl running around 90
    Sep 2013
    North palm fl
    Thanks so much makes sense to me I know they have hook built in just have to straight edge it see how much work to fix or not
    PARADISE /Naples
    working on the bottom is easy when boats is flipped over.
    Quote Originally Posted by Jeeper View Post
    its quite a bit different than just sanding a hook out, on the paramount. you cant change what daryl intentionaly designed onto(added) an existing bottom design, in an attempt to alter the boats existing performance, into a full time bow down performance boat, which he accomplished. it was not what he originally had in mind, but that's the way it ended up getting molded. it turned out to be a very nice, dry, little, 21 footer, that was affordable & looked kinda racy for a cc. the rather large, partial pad bottom wedge, is nothing that can be "removed", or improved upon, without major surgery, which just isn't practical to do. the much better option, if blistering speed is the objective, is to locate & buy one of the original boats that the paramount was copied from. the action marine 21 center console. looks identical other than the keel area.
  14. Likes XstreamVking, JBS liked this post
    daytona beach
    I've had mine at 70mph so far with no hull mods, but motor had issues and havent messed with setup or props. Only had a 23 pitch on it. Hopefully when the motors fixed and I play with setback it should be into the 80s. I'm running a 350 verado
  16. #13
    Jun 2012
    Indiana
    Im amazed at how well that hull holds the weight of that 350 Verado. What is the beam on the Paramounts?
  17. #14
    Mar 2017
    Miami, FL
    Quote Originally Posted by capteliminator View Post
    About 8' beam. They hold weight very well.
  18. Thanks capteliminator thanked for this post
  19. #15
    They are a small 21. As they were originally tooled using a shorter boat, a 19', which was/is commonly done. The beam is 86'' at the widest point. They are not a self-bailing boat.
  1. WTB: Paramount 21
    By sp543 in forum Hulls Wanted
    Last Post: 07-04-2020, 08:43 PM
  2. WTT for a 21 or 26' Paramount
    By lvnspeed in forum Hulls larger than 20'
    Last Post: 08-13-2018, 11:10 AM
  3. 21 Paramount
    By paramount paul in forum Hulls larger than 20'
    Last Post: 08-18-2015, 03:45 PM
