Page 5 of 12 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 LastLast
Results 61 to 75 of 166
  1. #61
    rotten transom, poor addition of secondary glass layers now delaminating
  2. #62
    Dec 2019
    Lake villa Illinois
    what material you pln on using for transom?
  3. #63
    I'm enjoying your build Pepperson4!
    this will be all composite build,
    [transom]
    2 sheets of 2 inch coosa on the transom, will be 4.5 inches thick when done,
    [stringers]
    heavy-weight foam upto 6 feet forward of transom, transitioning to lighter foam all the way to bow
    [hull-sides and tunnel-sides]
    light-weight foam on the sides and cap
    [laminates]
    intertwined carbon-kevlar
  4. #64
    Dec 2019
    Lake villa Illinois
    very nice. my transom was done in ply but it was 3" thick of wood lone so probably 3.5' thick when done, cant be tooo strong!
  5. Likes noli liked this post
  6. #65
    Feb 2006
    Brick NJ
    Just saw this outside by the Delaware river like two weeks ago tops?
  7. #66
    Day 1 of transom demolition
    Day 1 transom removal (port side)
  8. Likes mrichartz, LMT383, tnelsmn liked this post
  9. #67
  10. #68
    made cuts with circular saw, then use crow bar to break off large chunks
  11. Likes tnelsmn liked this post
  12. #69
    end of day 1
  13. Likes tnelsmn liked this post
  14. #70
    This tool works great, but I'm still scared of it --> #50
    the remaining wood is very thin and will be removed using big grain sand paper to expose the fiberglass
  15. Likes tnelsmn liked this post
  16. #71
    Jun 2018
    Floating around
    Yep them things can get grabby and talk your arms for a ride. Looking good
  17. Likes noli liked this post
  18. #72
    Happy Memorial Day. God Bless America & all who defend her and lost their lives!
    ...did about 1 hour of sanding today is all I had, gotta start the barbecues
    the port side is pure glass now, the stbd side will need grinding with the chain-saw wheel, then sanding
  19. Likes mrichartz, Pepperson4, tnelsmn liked this post
  20. #73
    had to install a new tube on the vacuum chamber in order to catch resin from going into vacuum pump
  21. #74
  22. Likes LakeFever liked this post
  23. #75
    vacuum drop test on newly added resin-catch tube
  24. Likes mrichartz, LakeFever liked this post
