Results 1 to 15 of 21
    Apr 2015
    Oceanside, NY
    225 efi Sneeze and sludge
    1996 merc 225 3.0L efi, motor sneezes on idle and has been spewing out some oily sludge from exhaust. Are these things related? Just took motor apart the other day, reeds are good, cleaned all injectors and fuel system. Has good fuel pressure and used all new gaskets. I'm at a loss here.
    Sneeze:
    https://youtu.be/I2golQi07T0
    Feb 2014
    Missouri
    Humm is it down on power?
    a miss can leave a wet slop add in some head gasket leak and you get bleh. Compression test probably in order. The sounds good on this vid the whiff sounds more like dead exhaust.
    The bleed lines can cause the sludge as well normally it will smoke when draining good but occasionally you get sludge as it mixes with reversion water.
    If you haven checked stator and could yet I guess dig in testing almost hate saying it.
    Apr 2015
    Oceanside, NY
    Stator is good, what should I check with bleed lines? Motor is not down on power.
    Apr 2015
    Oceanside, NY
    I exploded a lower unit a few weeks back, could something have happened to the lower crank seal when this happened? Could this explain the sludge and the sneeze?
    Sep 2017
    Ashland city tn
    That sludge would seem to b powerhead gasket but idk just a guess but really dont explain sneeze. Do all plugs look same after a idle?
    Feb 2014
    Missouri
    Possibly the sludge not so much the sneezing or miss.
    How did the lower blow up, say bad enough to mess up the drive shaft, or just prop shaft crack and bugger the gear?
    if bad enough and all that got twisted up it could have been enough to mess with the crank. Takes quite a blow up to damage much though. More or less second order damage.
  7. Thanks Seanj85 thanked for this post
    Apr 2015
    Oceanside, NY
    Lower blew up pretty bad was fully loaded with 200 gals of fuel, 3 guys plus bait and gear. it was the counter rotating lower that blew. Originally I thought the carrier just blew out, but when I opened it up there were all sorts of pieces inside it, nothing was salvageable. It was a pretty loud bang when it blew. I am going to pull the boat thursday for the season and pull the powerhead and take a look. Could a shot from the driveshaft really bend the crank?
  9. #8
    Apr 2015
    Oceanside, NY
    Quote Originally Posted by Merc 2.5 View Post
    Bottom plug looks very clean. All other plugs look normal.
  10. #9
    Sep 2017
    Ashland city tn
    Sounds like steamed cleaned. Prob powerhead gasket for the sludge , which mite b losing exhaust or sumthin thru it to and causing sneeze. Have u run compression test , maybe head gasket. if so. Comp would show it
  11. #10
    Jul 2002
    FT WORTH, TEXAS
    lower crank shaft seal is leaking!!!! water is mixing with gas and oil making that goop ive seen quite a few 2.5 do it
  12. Thanks Merc 2.5, Seanj85 thanked for this post
    Sep 2017
    Ashland city tn
    Ya that's what I was trying to say hahaha , guarentee texas is rite , some things dont "register " as easy without eyes on it.
  14. #12
    Jul 2002
    FT WORTH, TEXAS
    thats the most accurate statement ive heard in quite few days
  15. #13
    Jul 2002
    FT WORTH, TEXAS
    the fuel puddles on the inside of the block its about 1/4 recess for the fuel to accumulate on the top of the cap on a 2.5/3.0 and a bleed line carries fuel/oil to top crank bearing via crankcase pressure
  16. #14
    Feb 2014
    Missouri
    It could mess up the seal Tex and merc speak of. The shaft is more likely to give out befor the crank. But if one was close to the end the shock could end it. If you were running 5k and locked up and died when it blew all sorts of nasty things could happen.
    Doesnt sound that bad though.
  17. #15
    Apr 2015
    Oceanside, NY
    Pulled the boat today. Compression tested 90-95 across the board. Let the motor idle and sneeze for a while before dropping lower. attached are a few pics of the plugs. The first 2 pics are port bank (lowest on the right), the next 2 are stbd bank Also noticed some milky sludge inside exhaust cavity in mid. Click image for larger version.
ID:	450976Click image for larger version.
ID:	450979Click image for larger version.
ID:	450980Click image for larger version.
  1. Sludge in my oil tank
    By Cgriff in forum Technical Discussion
    Last Post: 08-03-2015, 03:07 AM
  2. Sneeze at idle
    By Blown Up in forum Technical Discussion
    Last Post: 04-29-2013, 09:22 PM
  3. What is a lean sneeze
    By xb03fs in forum Technical Discussion
    Last Post: 10-29-2009, 03:18 PM
  4. Mercury Tech: Sludge?
    By P man in forum Technical Discussion
    Last Post: 04-13-2009, 08:24 AM
  5. Oil injection - storage - sludge
    By Merculator in forum General Boating Discussion
    Last Post: 11-09-2008, 02:50 PM
