Results 1 to 15 of 21
Thread: 225 efi Sneeze and sludge
10-12-2019, 10:40 AM #15000 RPM
- Apr 2015
- Oceanside, NY
- 155
- 20
- 10
- 51
- 119
1996 merc 225 3.0L efi, motor sneezes on idle and has been spewing out some oily sludge from exhaust. Are these things related? Just took motor apart the other day, reeds are good, cleaned all injectors and fuel system. Has good fuel pressure and used all new gaskets. I'm at a loss here.
Sneeze:
https://youtu.be/I2golQi07T0
10-12-2019, 11:19 AM #26000 RPM
- Feb 2014
- Missouri
- 1,212
- 66
- 12
- 83
Humm is it down on power?
a miss can leave a wet slop add in some head gasket leak and you get bleh. Compression test probably in order. The sounds good on this vid the whiff sounds more like dead exhaust.
The bleed lines can cause the sludge as well normally it will smoke when draining good but occasionally you get sludge as it mixes with reversion water.
If you haven checked stator and could yet I guess dig in testing almost hate saying it.
10-12-2019, 11:23 AM #35000 RPM
- Apr 2015
- Oceanside, NY
- 155
- 20
- 10
- 51
- 119
10-12-2019, 01:03 PM #45000 RPM
- Apr 2015
- Oceanside, NY
- 155
- 20
- 10
- 51
- 119
I exploded a lower unit a few weeks back, could something have happened to the lower crank seal when this happened? Could this explain the sludge and the sneeze?
10-12-2019, 06:44 PM #5
That sludge would seem to b powerhead gasket but idk just a guess but really dont explain sneeze. Do all plugs look same after a idle?
10-13-2019, 01:12 PM #66000 RPM
- Feb 2014
- Missouri
- 1,212
- 66
- 12
- 83
Possibly the sludge not so much the sneezing or miss.
How did the lower blow up, say bad enough to mess up the drive shaft, or just prop shaft crack and bugger the gear?
if bad enough and all that got twisted up it could have been enough to mess with the crank. Takes quite a blow up to damage much though. More or less second order damage.
Seanj85 thanked for this post
10-14-2019, 03:16 PM #75000 RPM
- Apr 2015
- Oceanside, NY
- 155
- 20
- 10
- 51
- 119
Lower blew up pretty bad was fully loaded with 200 gals of fuel, 3 guys plus bait and gear. it was the counter rotating lower that blew. Originally I thought the carrier just blew out, but when I opened it up there were all sorts of pieces inside it, nothing was salvageable. It was a pretty loud bang when it blew. I am going to pull the boat thursday for the season and pull the powerhead and take a look. Could a shot from the driveshaft really bend the crank?
10-14-2019, 03:22 PM #85000 RPM
- Apr 2015
- Oceanside, NY
- 155
- 20
- 10
- 51
- 119
10-14-2019, 03:40 PM #9
Sounds like steamed cleaned. Prob powerhead gasket for the sludge , which mite b losing exhaust or sumthin thru it to and causing sneeze. Have u run compression test , maybe head gasket. if so. Comp would show it
10-14-2019, 08:17 PM #10Screaming And Flying!
- Jul 2002
- FT WORTH, TEXAS
- 8,031
- 9
- 146
- 313
- 503
lower crank shaft seal is leaking!!!! water is mixing with gas and oil making that goop ive seen quite a few 2.5 do it
10-14-2019, 08:34 PM #11
Ya that's what I was trying to say hahaha , guarentee texas is rite , some things dont "register " as easy without eyes on it.
10-15-2019, 09:11 AM #12Screaming And Flying!
- Jul 2002
- FT WORTH, TEXAS
- 8,031
- 9
- 146
- 313
- 503
thats the most accurate statement ive heard in quite few days
10-15-2019, 09:18 AM #13Screaming And Flying!
- Jul 2002
- FT WORTH, TEXAS
- 8,031
- 9
- 146
- 313
- 503
the fuel puddles on the inside of the block its about 1/4 recess for the fuel to accumulate on the top of the cap on a 2.5/3.0 and a bleed line carries fuel/oil to top crank bearing via crankcase pressure
10-16-2019, 12:58 AM #146000 RPM
- Feb 2014
- Missouri
- 1,212
- 66
- 12
- 83
It could mess up the seal Tex and merc speak of. The shaft is more likely to give out befor the crank. But if one was close to the end the shock could end it. If you were running 5k and locked up and died when it blew all sorts of nasty things could happen.
Doesnt sound that bad though.
10-17-2019, 05:54 PM #155000 RPM
- Apr 2015
- Oceanside, NY
- 155
- 20
- 10
- 51
- 119
Pulled the boat today. Compression tested 90-95 across the board. Let the motor idle and sneeze for a while before dropping lower. attached are a few pics of the plugs. The first 2 pics are port bank (lowest on the right), the next 2 are stbd bank Also noticed some milky sludge inside exhaust cavity in mid.
Sludge in my oil tank
By Cgriff in forum Technical DiscussionReplies: 2Last Post: 08-03-2015, 03:07 AM -
Sneeze at idle
By Blown Up in forum Technical DiscussionReplies: 5Last Post: 04-29-2013, 09:22 PM -
What is a lean sneeze
By xb03fs in forum Technical DiscussionReplies: 3Last Post: 10-29-2009, 03:18 PM -
Mercury Tech: Sludge?
By P man in forum Technical DiscussionReplies: 9Last Post: 04-13-2009, 08:24 AM -
Oil injection - storage - sludge
By Merculator in forum General Boating DiscussionReplies: 3Last Post: 11-09-2008, 02:50 PM
