Page 2 of 2 FirstFirst 1 2
Results 16 to 21 of 21
    Apr 2015
    Oceanside, NY
    If the lower crankshaft seal is bad would I see milky gas/oil around driveshaft when I pull the lower?
  2. #17
    Apr 2015
    Oceanside, NY
    Quote Originally Posted by TEXAS20225 View Post
    lower crank shaft seal is leaking!!!! water is mixing with gas and oil making that goop ive seen quite a few 2.5 do it
    If the lower crankshaft seal is bad would I see milky gas/oil around driveshaft when I pull the lower? Pulled it today and didnt see anything except for a little bit of normal oily residue
  3. #18
    Sep 2017
    Ashland city tn
    Can u look with a light and see if in water in bottom cyl? Or on the plug
  4. #19
    Jul 2002
    FT WORTH, TEXAS
    ????there will only be the goop in the exhaust adapter where drive shaft enters lower cap there is no normal oily drive shaft its supposed to be dry
  5. #20
    Apr 2015
    Oceanside, NY
    I guess off with the powerhead it is. Dang, was hoping I wouldn't have to do this.
  6. #21
    Jul 2002
    FT WORTH, TEXAS
    a 3.0 is easier then a 2.5 it take very little time just have your new gasket and new seals for lower cap it take two of them pay attention how they come out good luck you are furthering your education
  1. Sludge in my oil tank
    By Cgriff in forum Technical Discussion
    Last Post: 08-03-2015, 03:07 AM
  2. Sneeze at idle
    By Blown Up in forum Technical Discussion
    Last Post: 04-29-2013, 09:22 PM
  3. What is a lean sneeze
    By xb03fs in forum Technical Discussion
    Last Post: 10-29-2009, 03:18 PM
  4. Mercury Tech: Sludge?
    By P man in forum Technical Discussion
    Last Post: 04-13-2009, 08:24 AM
  5. Oil injection - storage - sludge
    By Merculator in forum General Boating Discussion
    Last Post: 11-09-2008, 02:50 PM
