Page 2 of 2 FirstFirst 1 2
Results 16 to 24 of 24
    Sep 2017
    ontario
    typically the c;ear would be the UV topcoat . The more clear vs yellow the clear is generally amounts to higher quality and as well carries a higher solids vs solvent content UV inhibitors are high in good quality clears . This situation isnt much differant than someone clearing/topcoating over bare metal on a Rat Rod or a kevlar to show off its characteristics.
  2. Likes noli liked this post
  3. #17
    the next candidate for epoxy primer
    https://www.screamandfly.com/showthr...19#post3167219
  4. #18
    Jan 2007
    Amityville/Lindenhurst
    You want a satin finish clear or topcoat
    You have to sand the primer if you intended to clear it, it wont be even enough to clear over. after clearing over it it will still be shiny. no different then if you used basecoat/clear coat. when you spray basecoat its a matte finish its not shiny. put clearcoat over it and its shiny.
    you can also paint it a matte finish but it takes a really good painter so it comes out even. it then cant be repaired/blended or sanded and polished.
    paint the boat, then wrap or I cant even believe im saying this- spraywrap the boat in a matte finish.
  5. #19
    If you look closely at 545 in the sun you can see colored bits shining back. It seems metallic looking close up. I have thought it might look good as a rat rod finish. I have had 545 out in the fl sun for months and saw no fading or change at all.
    Mar 2016
    cincinnati, ohio
    Can this primer be rolled on or do you have to spray it on????
  7. #21
    Mar 2009
    Saint Lucie Florida
    Gray 545, no clear or topcoat, I agree I love the look of bare primer, my boat will be almost the same color gray with awlcraft 2000.
    Attached Thumbnails Attached Thumbnails IMG_20191111_181630.jpg   IMG_20191111_181614.jpg   IMG_20191111_181651.jpg   00100lPORTRAIT_00100_BURST20191111171614049_COVER.jpg   00100lPORTRAIT_00100_BURST20191111171620080_COVER.jpg
  8. Likes noli liked this post
  9. #22
    The "Pro use only" is so their azz is covered when you don't cover yours ...
    Try painting in Florida with the full space monkey suit ....
    Chaz = thinking, this is being way over thought ...
    Epoxy is a sealer / primer .. don't like how it looks with clear .... don't clear it.
    Anyway, they closed my local paint store 20 years ago. I use this on steel projects to keep them from rusting .. leave it outside, hit it with a hammer, let it fall out of the truck bed at 10 mph, it's still there .. IT'S EPOXY
    https://tcpglobal.com/collections/ep...rdener-1-1-mix
    PS .. I use their "HotRodFlatz" gloss black over it on all my roll cages and Merc mid section parts .. good stuff, priced right ..
  10. #23
    I made a big mistake painting my GMC truck frame with POR15 years back after dewaxing it. I thought it was epoxy. Its not. Wasn't paying attention. Wondering what black epoxy I can now use, that's brushable, that's preferably catylized, that I can go over the POR15 with?
  11. #24
    Jan 2009
    Lafitte, Louisiana/ Beaumont, Texas
    Fujimo, take a look into macro epoxy 646. Maybe it can help ya.
    Modded Hydrostream Vking
    Hydrostream Vking
    Hydrostream Viper
    Sold, Hydrostream Vector, Allison xb2002
  1. 545 epoxy primer over bare steel
    By mrcrsr in forum Fiberglass and Composites Discussion
    Last Post: 07-19-2016, 04:34 AM
  2. epoxy primer Dupont..... Imron paint
    By roadkill636 in forum Misc. Parts and Accessories
    Last Post: 03-04-2015, 05:26 PM
  3. automotive epoxy primer
    By BahamaBoy in forum Fiberglass and Composites Discussion
    Last Post: 06-13-2008, 09:09 AM
  4. ppg epoxy primer
    By 77sst in forum Fiberglass and Composites Discussion
    Last Post: 03-30-2006, 08:33 PM
  5. My Vector In Epoxy Primer
    By Instigator in forum General Boating Discussion
    Last Post: 03-14-2002, 11:18 PM
