Results 1 to 15 of 24
    anyone use 545 epoxy primer?
    Hi, I want to prime a boat with 545 epoxy primer
    can this take on a clear coat?
    Jun 2001
    yup- just painted my Vampire using that as the primer..
    easy to work with and sand
    just curious if you clear coated?
    usually gunners use a real paint on top of 545, I just want to clear it
    have you clear-coated any 545 primer?
    Jun 2001
    no i put a top coat over it. no help here
    please share pics
    would love to see what you've done
    Sep 2017
    ontario
    I am not familiar with 545 primer but if it' an epoxy primer and your topcoating it with a urethane clear I dont think you will have any issues. That is as long as you follow correct mixing of catalyst and allow the primer to flash off before . I dont understand your thinking on clearing the primer but I believe applying clear over it will be fine . Call their tech line for further technical info if available . Hope that helps
  7. Likes noli liked this post
    You can color tint the 545. I have used it on every boat that I have done but always went over it with Awlcraft or Awlgrip.
  9. Likes noli liked this post
    yes Joe you hit the nail right on
    I've seen DW in past deliveries of the DW32 where the "finished" hull is ready for paint and all it had was 545 epoxy primer and I thought that it was beautiful in that finish
    Why am I doing this?
    I'd like to try giving my boat different look, I also want a durable finish
    the clear is to show off the shine of the hull
    and as Joe mentioned, we can tint the epoxy so that we can still reach a good and beautiful color on a primer
    that's my goal, just to try sth out
    image below says "Professional Use Only"
    I am not a pro by any stretch of the imagination....muhahahaha
  12. Likes mrichartz liked this post
    Sep 2012
    I am struggling to see what result you want. There are topcoats that can look like tinted prime that are proven.
  14. #11
    I want this look, but when you apply clear, the boat gets shiny
  16. #13
    Before you lay down the topcoat, a good primer is needed
    I want to lay down the primer and stop there
    Don't want to add any top coat,
    Following the 545, I'd like 3 coats of clear
    I'd like to know why this is a bad idea
  17. #14
    8 Post(s)
    Quote Originally Posted by noli View Post
    Typically epoxy doesnt survive in the sun.
  18. Likes noli liked this post
  19. #15
    Power,
    That's a good point!
    I'll find out if adding tints would help prevent that
  1. 545 epoxy primer over bare steel
    By mrcrsr in forum Fiberglass and Composites Discussion
    Last Post: 07-19-2016, 04:34 AM
  2. epoxy primer Dupont..... Imron paint
    By roadkill636 in forum Misc. Parts and Accessories
    Last Post: 03-04-2015, 05:26 PM
  3. automotive epoxy primer
    By BahamaBoy in forum Fiberglass and Composites Discussion
    Last Post: 06-13-2008, 09:09 AM
  4. ppg epoxy primer
    By 77sst in forum Fiberglass and Composites Discussion
    Last Post: 03-30-2006, 08:33 PM
  5. My Vector In Epoxy Primer
    By Instigator in forum General Boating Discussion
    Last Post: 03-14-2002, 11:18 PM
