Results 31 to 45 of 45
10-10-2019, 04:23 PM #31Member
- Apr 2016
- Frederick, Maryland
- 34
Oh it's fun that's for sure done and done no difference with either the main plug unplugged or shift interupt switch disconnected FYI this is a jet outboard so the interupt switch is never used. This has been the issue with the motor since the day I purchased it without knowing of this problem it had great spark and good even compression how bad can it be LMAO here we are over a year later
10-10-2019, 04:24 PM #32Member
- Apr 2016
- 34
Nitro could you please explain why my previous post rules out the flywheel thanks
10-10-2019, 06:09 PM #33Member
- Oct 2019
- Clearwater, Fl.
- 61
- 10
Well basically a flywheel is static, it does not change. And what your describing is electrical/electronics. When it drops from 5500 down to 2500 or so, and then you can recover by manipulating the throttle, flywheel can't do that. It sure sounds like a timer base or pack trying to go into SLOW.
Does this happen with the reg. out of circuit?
10-10-2019, 06:10 PM #34Member
- Oct 2019
- Clearwater, Fl.
- 61
- 10
What's your complete model #
10-10-2019, 06:17 PM #35Scream And Fly VIP
- May 2001
- Hickory NC
- 5,583
- 18
- 250
- 204
- 464
- 4 Post(s)
One thing I noticed is you mentioned 0 to 1000V on the orange wires. These are your quick start wires not your ignition charge coils those are brown. The charge coils also will not make any where close to a 1000V so something else is wrong. What is your voltage at the ignition coil when running 1000RPM and again at 2500, if your meter is correct you should have between 150 and 200 at 1000RPM and go up to about 240 at 2500
10-11-2019, 06:42 AM #36Member
- Apr 2016
- 34
10-11-2019, 06:50 AM #37Member
- Oct 2019
- Clearwater, Fl.
- 61
- 10
10-11-2019, 06:54 AM #38Member
- Apr 2016
- 34
Okay so here's an update talked with cdi electronics I am to send the entire ignition system including the flywheel to them they are going to install it on their test motor to find the issue if they can't I'm done with it so let me know if you are interested in parts I will be making deals
10-11-2019, 06:54 AM #39Member
- Apr 2016
- 34
10-11-2019, 07:10 AM #40Member
- Oct 2019
- Clearwater, Fl.
- 61
- 10
That! ... Was my next idea. The people at CDI are Great! They will go above and beyond what we call service today.
Side Story: I had a 70 Hp 3cyl Evinrude come to my shop with a DEAD MISS! No doubt about it ... This thing had a DEAD MISS!! So I started pullin plug wires to find the bad hole. Pulled #1, no change, #2, no change, and #3 ... NO CHANGE! But There was a dead miss you could not deny!
It was the Pack! For some reason it would not fire all three. And when you would pull a firing cylinder, it would pick up the offending cylinder!
I sent that pack to the OMC training center in Sawgrass Fl. So they could have some fun with their students in the test cells.
Electrons do funny things!
Please get back to us when CDI figures out what's amiss!
Thanks;
D.
10-11-2019, 07:17 AM #41Member
- Apr 2016
- 34
I will make sure to update the post with the findings thanks for all the help
10-12-2019, 08:06 PM #42
I had the exact same issue. Spent a summer chasing it. Bought all brand new CDI digital stuff racing stuff. was better but not quite right. Ended up being the internal timing magnets had a few cracks in them. Nothing to do with the outer magnets. Reluctantly bought a new flywheel and the problem was solved. On a timing light they were sparking willy nilly. I have a few videos on youtube showing the issue. But it sounds just like what I went through. If anyone has ever put a flywheel puller on the flywheel and gave it a whack with a hammer, that's all it takes to crack 29 yr old magnets.
Nitro25 thanked for this post
10-13-2019, 08:15 AM #43Member
- Oct 2019
- Clearwater, Fl.
- 61
- 10
Hey Krazzymaan
So what you're saying is that the ferrite magnet is fractured behind the shield and not visible in the trigger windows, and in you're case the shield did not migrate out of phase? ... We had all kinds of weird problems with flywheels, but usually with the windows migrating out of phase. If the magnet fractured vertical, it would create a new set N/S poles, but you would think the stainless window shield would mute, or dampen the lines of influence. But if the fracture was horizontal passing across the face of the trigger window, you would have two new sets of poles who's lines if influence would run 90* out, who knows what the trigger would see. I have a PC microscope that I use for circuit boards that could see that.
D.
10-13-2019, 08:18 AM #44Member
- Oct 2019
- Clearwater, Fl.
- 61
- 10
How can we find your video?
10-13-2019, 08:36 AM #45
77 115 johnson ignition issue
By John800 in forum Technical DiscussionReplies: 12Last Post: 07-25-2017, 06:06 PM -
1990 200 looper issue
By warpt in forum Technical DiscussionReplies: 4Last Post: 08-10-2016, 06:05 PM -
1990 Johson 150GT VRO issue
By FishfulThinking in forum Technical DiscussionReplies: 7Last Post: 03-10-2012, 07:22 AM -
1990 evinrude 200 spark issue
By mountainfreik in forum Technical DiscussionReplies: 2Last Post: 04-28-2011, 09:50 PM -
1990 GT 200 starting issue.. HELP !!
By Vinnie in forum Technical DiscussionReplies: 3Last Post: 03-15-2007, 10:57 AM
