Results 16 to 30 of 44
    Aug 2014
    West Bend, WI
    I finally got the guts and flipped my hull. wasn't that bad. I found that lifting the stern from the center kept things from being very exciting. I working at fixing where the previous owner add glass the bottom at the stern. I'm a little concern with the transom. Its not flat. the last 3 inches or so curve toward the bottom. He installed a new transom, So who knows what was or was not done.
  2. #17
    Sep 2010
    arkansas
    Quote Originally Posted by Poky View Post
    Well, it don't look good for the home team.
  3. #18
    Aug 2014
    West Bend, WI
    Well, I'm just a dumb white boy, so I'll just keep going forwards. My west epoxy is all cured, and bottom is now solid. Now to make it flat and smooth.
  4. #19
    How much would it weigh finished no motor on it?
  5. #20
    Sep 2010
    arkansas
    It was 725 shipped.
  6. #21
    Sep 2010
    arkansas
    Be careful what you use for filler. Epoxy is picky about what will stick to it.
  7. #22
    Aug 2014
    West Bend, WI
    I use all the West Epoxy system. I use their fillers and additives. it grabs onto anything. I've had it grab onto a plate of 1/2 glass that i was using to make a flat surface. Its not cheap, but it will definitely grab onto old fiberglass.
  8. #23
    Quote Originally Posted by tunnelfun View Post
    It was 725 shipped.
    You build a strong runner and setup it'll be fun.
  9. #24
    Aug 2014
    West Bend, WI
    working on what color to paint it. Love the green, But with all of the glass work, there just isn't any way.
  10. #25
    Sep 2010
    arkansas
    If your epoxy has cured there will be no chemical bond. Just mechanical from sanding.
  11. #26
    Aug 2014
    West Bend, WI
    I'm not real sure, but the west stuff will rip the old glass off if you try to get it off. and like I said, I couldn't get it to let go of a plate of glass surface. I've used it of years, I've seem normal resin pull away from old fiber glass.
    https://www.westsystem.com/
  12. #27
    Sep 2010
    arkansas
    Yes, good stuff. Epoxy doesn't chemically bond to cured epoxy. Just mechanically, sand it good.
  13. #28
    Aug 2014
    West Bend, WI
    after far too long, i finally got the Chrysler on the boat, mounted to a 5 inch manual jack plate, transom got a knee that ties it to the single stringer. and now i get to figure out steering and controls.
ID:	488856Click image for larger version.
  14. Likes tnelsmn, FMP liked this post
  15. #29
    Aug 2014
    West Bend, WI
    Got one step closer to running, I got the exhaust snout cut and move back so I could run a chopper on my Chrysler, should be interesting to see how it effects power. Getting close to getting her wet soon,Click image for larger version.
  16. Likes FMP liked this post
  17. #30
    If you reduced the snout area cross section drill a couple holes above the cav plate, typical relief.
    When using a 40-60hp snout on that lower to clear high rake , it hated the reduced cs.
    You should be mounted high enough, take advantage of the side bullet intakes.
    If you find a 92-94 FORCE 3/4/5 parts motor use the later BIA clamps and pump with lines. The trim tilt rams are the same as previous CHRYSLER. It makes using a typical jackplates easier. Almost looks like you did from the pic , can't see it but they are painted white.
  1. CeeBee Avenger Project: See link!
    By croSSed in forum Fiberglass and Composites Discussion
    Last Post: 04-26-2021, 05:29 PM
  2. Cee bee avenger jet boat for sale
    By tmeyer56 in forum Jet Boats, V-Drives and Stern Drives
    Last Post: 07-22-2014, 12:50 AM
  3. avenger bass boat
    By duke1 in forum General Boating Discussion
    Last Post: 06-29-2009, 07:50 PM
  4. Potential 1980 18ft avenger project boat..??
    By SUPAJAY in forum General Boating Discussion
    Last Post: 09-21-2007, 04:50 PM
  5. Rabco - Avenger Same boat?
    By Bruster in forum General Boating Discussion
    Last Post: 10-16-2005, 07:47 PM
