Results 1 to 3 of 3
Thread: Good or Bad Idea
10-07-2019, 08:33 PM #15000 RPM
- Mar 2018
- NJ
- 196
- 10
Good or Bad Idea
I seem to lost fuel prime on a 1997 200 efi. I have to do 3 starts before it will run each time with minimal down time say 1-2 hrs,once running no problem. I was thinking of adding a low pressure(2-3.5)electric fuel pump to eliminate this,i have gone over the hoses and clamps. Good or Bad Idea. Thank you
10-07-2019, 09:22 PM #2Screaming And Flying!
- Jul 2002
- FT WORTH, TEXAS
- 8,031
- 9
- 146
- 313
- 503
what about fuel bulb it has a one way valve in it to keep fuel from draining back in tank!!!! u may need to rebuild pulse!!! pump cost about 10 bucks and a no brainer
10-08-2019, 05:07 AM #3
X2 ^....Also make sure the bulb is vertical and out outlet is facing up.
Is this a good idea or not?
By hugetime1 in forum General Boating DiscussionReplies: 6Last Post: 04-25-2013, 03:45 PM -
Mercury Tech: Mercury's not so good idea?
By Forkin' Crazy in forum Technical DiscussionReplies: 61Last Post: 10-14-2009, 02:16 AM -
good idea??
By cterrebonne in forum Technical DiscussionReplies: 2Last Post: 10-11-2006, 10:05 PM -
Good Idea?.......
By sosmerc in forum Technical DiscussionReplies: 2Last Post: 03-31-2003, 09:59 PM
