Results 1 to 15 of 17
    Aug 2005
    West Allis,Wisconsin
    Voltage Regulator
    Is a voltage regulator needed on a 16 amp stator on a 225 EFI?
    Nov 2003
    Simi Valley, SoCal
    Quote Originally Posted by seansbaja1982 View Post
    I would say yes since it's EFI. Even the old 2.4's had regulators on the EFI's. I don't know if the ECU has a regulator or protection for over voltage but it would be an expensive experiment if not.
    96 Cougar 23 MTR twin 300XS's. 100 something
    98 Laveycraft Sebring 20.2 Tunnel 280 90 something SOLD
    85 Baker RST 220 Laser SOLD
    Aug 2005
    Thanks, I wonder if 16 amp is enough to power EFI, radio-amp, trim and gages?
    Feb 2011
    HUDSON, FLORIDA
    I Would say yes, lots of efi motors came with 16a systems, for years.
    Nov 2003
    Simi Valley, SoCal
    I had a 2.4 220 EFI with a 14 amp. It did work but I would not recommend a big sound system or a bunch of extra electronics. I think I had a 100w amp and was careful of how many hours I ran it vs how long I ran the boat. There isn't much left to charge the battery after running the trim, jack, ECU and fuel pump. If you can charge the battery at night or spend a lot of time running around you will be fine. It really doesn't charge until you get the RPMs up so keep that in mind. I bought a 40 amp setup but never got around to installing it so it must have not been too bad...
    Baton Rouge, La
    I ran a 16 amp 260 with a 50w per channel radio ,trimming while running, and plenty of starts because I don't shift while running and never had a problem. I did try to charge it between trips.
    And no 16 amp usually uses a rectifier not a regulator
    Cheaters never Win !!!
    Apr 2017
    pa
    5 Post(s)
    but some people run a single regulator on their 16amp system
  8. Likes tunnelmike liked this post
  9. #8
    Apr 2019
    Canada
    I have a 2.5 260 EFI. It has both rectifier and regulator in it. I just run the basics (ecu, trim, gauges, fuel pump, no sound system) and find i barely have enough amps to maintain a slow drain on the battery. I need to run about 5k RPM to get any charge and if i am choking the hell out of it the added draw of the fuel pump bests the charging system. Some company makes an after market 40 or 60amp alternator kit that bolts on to the 260 that i was thinking about getting. That said, for short days when i can charge battery at the end of the day i am usually ok.
  10. #9
    Jul 2002
    FT WORTH, TEXAS
    16 amp systems have a regulator and rectifier from the factory on all early motors i know plenty of times i lost track of time lifting them 12 oz weights and jamming to the tunes come to only to find they waited to long and need a jump start me i ran off trolling motor battery's not starting battery because after fishing all day running live well and radio i found myself having to jump it off to get going. no live well problem not as bad
  11. #10
    Baton Rouge, La
    Choking ' you have a charging problem or a bad battery. I could stay out all day with lots of starts and radio playing with an automotive battery running under 3500 r's and never had a problem. No regulator. Just standard 16amp set up.
  12. Likes David - WI, KIRCHNER liked this post
    Apr 2019
    Canada
    Tunnel - New battery, rectifier and regulator this season. I also had the stator tested and it was ok. I was told that the fuel pump i am running has a larger draw than most. Dont get me wrong, if I can avoid 10km (in Canada) zones and keep moving at a good clip i can get a days use out of it. Throw in some speed restricted zones or excessive trimming and it gets problematic.
  14. #12
    Apr 2017
    pa
    5 Post(s)
    I run rectifier only and never had a problem fishing all day. Mine is a carb motor though
  15. #13
    Baton Rouge, La
    I have no experience with 16amp with regulators. Just putting out my experiences
  16. #14
    Minneapolis MN
    Any of you running AGM (Optima) batteries with stator charging? Reaching the point of needing to glass in a battery mount in my build and trying to figure out what battery to go with.
  17. #15
    Aug 2005
    Thanks for the input everyone...
  1. Voltage regulator
    By CNT in forum Technical Discussion
    Last Post: 06-09-2004, 05:19 PM
  2. Voltage Regulator
    By STV_Keith in forum Technical Discussion
    Last Post: 01-08-2003, 08:39 PM
