Results 16 to 30 of 31
Thread: XR6 advice
    Apr 2017
    pa
    5 Post(s)
    Im pretty sure i have a few sets of wmv-18's rather than playing with jets on your 150 carbs.
  2. Thanks Dewey-05 thanked for this post
  3. #17
    Jul 2002
    FT WORTH, TEXAS
    i would suggest that also because main jets are considerable bigger and air jets a lot smaller . i re jetted some 16s once for a 200 and the motor leaned out normal mains in the 16's were 74 i went to 78 it was not enough i guess but then im not a carb guy as a matter of fact any one who knows me know i hate carbs im total efi
  4. Thanks Dewey-05 thanked for this post
  5. #18
    Jul 2012
    Lufkin, Texas
    I've only used 2.4 WH carbs on the 2.5's I've modified. Much easier to play with than the WMH's. Going to stock 2.5 200, I'd probably go with stock 2.5 200 carbs though!
    Like TX said, you can just cut your tuner to the 200 length, if you go with the Bob's tuner you have to throw away the liner in the can which you may or may not want to do...
  6. Thanks Dewey-05 thanked for this post
  7. #19
    Oct 2019
    Alabama
    Thanks guys,, the mechanic I was going to get to bolt it on acts like he doesn’t want to try it, doesn’t think it will work. So now I’m debating about trying to do it myself. I like a challenge, it’s not working anyways right lol.
  8. #20
    Apr 2017
    pa
    5 Post(s)
    Dont want to try what?
  9. #21
    Oct 2019
    Alabama
    Putting a 200hp powerhead on instead of the original 150hp powerhead, and he’s wanting around $1k to swap and check carbs, new water pump ( which I installed a new one in spring and have had it in the water maybe 6 times since I’ve installed it, not even 6 hrs on it,, we have small lakes here ).
  10. #22
    Apr 2017
    pa
    5 Post(s)
    Geesh. Sounds high to me. Maybe you should shop around for a more understanding mechanic.
  11. #23
    Jul 2005
    AZ
    A grand!? To bolt on a powerhead, swap carbs and a water pump? Damn sounds like he's giving you a, I don't want to do it price...
    '84 Checkmate Convincor
  12. #24
    Oct 2019
    Alabama
    Yea that’s the problem.. there’s only 2 local. The rest are about hour or more away. By the time I bought the powerhead and paid him to hook it up, I can buy a descent used motor. He also seemed to think the powerhead im looking at doesn’t come with reed housing. I’ll try to post the link and see what y’all think
    https://www.ebay.com/itm/Remanufactu...6370%7Ciid%3A1
  13. #25
    Oct 2019
    Alabama
    Yea, that’s what I’m thinking myself, check the carbs, new water pump and check the lower he said.. he was going to take it to the lake also and make sure it worked ( 1/4 mile down the road, you can see the lake from the driveway).
  14. #26
    Pekin, IL
    So he wants $3000 for a rotating assembly. I sold a Mariner with 6 new pistons complete from cowling to lower unit for $3500 a couple months ago. There are some good deals out there right now with winter just around the corner.
    Rock
    Team Junk
  15. Likes nitro_rat liked this post
  16. #27
    Oct 2019
    Alabama
    I found what I REALLY want. My heart is set on it,, but unfortunately my heart is bigger than my credit limit.. it’s a 2003 Mercury 225 efi with 230hrs. He won’t come down on the price to my budget tho. I can’t blame him
  17. #28
    Jul 2002
    FT WORTH, TEXAS
    3.0 are a little heavier then the 2.5 motors . i built a Eric Simon 3.0 for my Bullet years ago and i put all the best stuff in it!!! it started life as a 250 i had James Perry remove the sleeves and add 6 new 300x sleeves in it had ecm refreshed to 300x with a rev limit raised up to 7800, light flywheel, vertex pistons, cut heads , rods/ piston matched to almost identical weight, cut liner, added the bs poppet deal , C Carson reeds, lapped and modified cages after all was said and done it lacked 3 mph being as fast as the the 280 i took off to put this thing on not to mention i hated the back wash from the extra weight set back there 15" from the transom it was not a good set up it did not have the hole shot the 280
  18. #29
    Jul 2002
    FT WORTH, TEXAS
    yeah i guess i sold them too cheap my self compared to today's pricing,i sold a bunch of rebuilt merc for 4000/4500 installed, where are you in Al. i used to come down there to buy motors , Guntersville, Birmingham to name a couple
  19. #30
    Oct 2019
    Alabama
    I’m in Andalusia It’s about 3hrs south of Birmingham.
  1. Need some advice...
    By CJSXR800 in forum General Boating Discussion
    Last Post: 08-18-2014, 10:58 AM
  2. need advice
    By yasser in forum Technical Discussion
    Last Post: 07-14-2014, 10:35 AM
  3. Set-up Advice Please
    By Oz Dude in forum Props, Setup, and Rigging
    Last Post: 01-05-2009, 11:22 PM
  4. GPS Advice
    By mk55 in forum Outboard and Racing History
    Last Post: 12-21-2007, 04:59 PM
  5. Please Help, I need advice
    By Joe Don in forum General Boating Discussion
    Last Post: 06-24-2003, 06:59 PM
