Results 31 to 45 of 45
Thread: Mercury 300’s
10-08-2019, 11:58 AM #31
10-08-2019, 06:45 PM #325000 RPM
- Sep 2014
- Florida
- 420
- 15
- 25
- 127
The i6 verado platform in my eyes is pretty tapped out for power on pump fuel. Chaz you know cams in supercharged applications has minimal gains compared to N/A. The 4.6l will be on back of a lot of boats assuming you can turn 225-250 up with bolt on cams I bet there will be a big market. Also I already heard about pistons kits being made. Time will tell I guess
#skaternation
21 rally sport (sold)
21 Cougar (sold)
21 Skater (sold)
24 skater (sold)
21 Armstrong (fishing deck) 250 etec
24 SEB (soon to be laid up)
10-08-2019, 06:47 PM #33
The 300xs Tuff 28 is also 800-1000 lbs lighter than the 300R boat. Also, the 21-22 Liberators that run 10-12 mph faster than the 300xs powered Liberators, only do it with 5 blade 15.25 diameter cleavers. Both the Mercury CNC's or the Hill 5 blades which I sell for $2150 to your door.
Boat Delivery available
Things owned. NOTHING!!
RSWORDS liked this post
10-08-2019, 07:29 PM #346000 RPM
- Jul 2011
- Gloucester, VA
- 1,311
- 19
- 90
- 180
- 342
10-08-2019, 09:56 PM #355000 RPM
- Aug 2007
- DE WITT AR
- 276
Wildman, I know know that you have rigged a bunch of the 21 Liberators and that you felt like you were getting almost all the performance out of the 300xs. Why then is the v-8 so much faster? I know that it takes a lot of torque to get up to speed with a 5 blade large diameter cleaver but I still think that it takes a lot more horsepower to run 10 mph faster.
David Borg thanked for this post
10-08-2019, 10:22 PM #36
10-09-2019, 07:18 AM #37
"The 300xs Tuff 28 is also 800-1000 lbs lighter than the 300R boat." That's a lot of weight difference for two boats that on the surface look the same. Its not like one is stripped down race boat. I am guessing one is a carbon boat and the other glass. But i am guessing both are bagged boats. The prop cost difference to make the 300R run is a big negative. Maybe another year or two and they will have it figured out.
Just a little Cat.
24 Twister V8 E-Rude (For Sale)
2008 Concept Sport Deck 2x 300X
10-09-2019, 07:25 AM #38Screaming And Flying!
- Jul 2004
- Connecticut
- 6,010
- 465
- 168
- 911
- 951
Where did the 800lbs lighter come from?
10-09-2019, 08:42 AM #39
I was told that the carbon fiber 300xs boat (bare hull) was 1400-1500 lbs. The bare hull weight of the 28 that I put together was 2750 lbs.
and it has run 101 with 300xs motors. I was told the heavier 300R Tuff 28 has run 105.
The 300R is supposed to be 332hp. As far as the 300x, I NEVER had a 300x run faster than a 300xs on ANY BOAT I rigged, Checkmate or Liberator or my 21 Superboat. They have all had both motors. Just my personal expierience.
10-09-2019, 11:20 AM #40
blkmtrfan liked this post
10-09-2019, 01:33 PM #41
Regardless of the weight and speed difference, I gotta say that the Tuff 28 is the fastest and best handling V-bottom I have ever driven!
10-09-2019, 05:16 PM #42Supporting Member
- Apr 2003
- New Smyrna Beach, FL./LOTO
- 6,644
- 606
- 923
- 1698
- 7147
- 3 Post(s)
There will 15" aftermarket mids available by the end of the year, Mercury already has stuff well under way for them as seen late last week Via. internet speculation and leaks. They have short midsections and power increases that will be game changers for the guys willing to spend the money. There are a couple of car based aftermarket companies involved with product development that will be coming to market with there products in the near future as well. We are already seeing cowl modifications that are gaining an additional 2-3 mph with better mid-range running around. My guess is that 450 hp, 7000 rpm motors will be on the water next spring. This is only my guess based on the little bit of information that I have been exposed to but I can tell you that its coming from several directions and I will be part of it when its available.
V-bottom thanked for this post
10-10-2019, 10:55 PM #43
No, I wasn't aware of that. I have always been under the impression that the camshaft controlled the valve events. Which dictates at what RPM the torque peak will occur and how long it will hold it. If you don't think it matters, get a good running wood chipper
(blower motor) and knock 20* of duration off of each lobe profile. It will detonate off the bottom and fall on it's face on top.
We have went over this before I think , but yes I agree. The factory put the vertigo package together to where it makes 400 HP on pump fuel. I don't know how much boost they make (or care) but lets call it 20 psi (substained)
If you opened the head up to where it blows 15cfm better on average and bumped the sticks up 5* intake / 10* exhaust and ran it , I'll bet it "only" makes 12 to 15 PSI of boost yet runs faster. Remember "boost is only "back pressure" in the intake tract .. And since everything was built to go 20 PSI plus a margin of error, it could be retuned for 20 PSI and the limiter raised to get there .. anddddd
But look , what do I know, I'm just an old man ... BTW this is my last personal chassis I built, looks like Willie is startin to get a handle on it himself ...
10-11-2019, 04:40 PM #445000 RPM
- Sep 2014
- Florida
- 420
- 15
- 25
- 127
I’m not well informed enough about the i6 to know where the restriction is but I’m not saying cams don’t matter but I’m was just saying they don’t possess the same gains as n/a motor. Also yes I understand that you can reduce the boost pressure but that doesn’t mean the blower is going to flow more cfm. I seen the stuff you built you forgot more than I know.
My question to you it when you going to drag your boat out and getting it going again.
that dragster is awesome!!#skaternation
21 Cougar (sold)
21 Skater (sold)
24 skater (sold)
10-11-2019, 11:24 PM #45
OK, I'll build a 434ci SBC with a set of Brodix 18* heads. .750 lift 285*@ .050 intake /.700 lift 290* @ .050 ex. Split 114 Should make 900 @ 8500 .. pick a better cam
Then put a stick out of a mid 70's 350 van in a 434 blower motor .390 lift 195* .. then put the right one in it ... see my point. Depends where you start from top shelf or junk yard .. it's just as inportant to one as it is to the other ..
While it's true you can turn up the pressure to try and make up for a poorly designed system. I have found that it tends to just overheat the air and throw a lot of belts off and not really run any faster.
Unless it's a set of these or something like them, then there's very few stock production heads that can't be improved. Some drastically .. with very little work.
Add the right camshaft ( to the new flow numbers ) and it can't help but use the available air to make power instead of moving the needle on a gauge..
Mercury key switch harness conversion for old school inline six Mercury
By Phil Conant in forum Misc. Parts and AccessoriesReplies: 4Last Post: 06-04-2015, 06:34 PM -
Article: Mercury Racing Blog: Team Mercury - Part 2: Reggie Fountain
By Scream And Fly in forum vBCms CommentsReplies: 8Last Post: 03-16-2012, 05:43 PM -
Article: Mercury Racing Blog: Team Mercury – Part 3: Earl Bentz
By Scream And Fly in forum vBCms CommentsReplies: 0Last Post: 02-04-2012, 07:55 AM -
Article: Mercury Racing Blog: Team Mercury – Part 1: Bill Seebold
By Scream And Fly in forum vBCms CommentsReplies: 0Last Post: 01-15-2012, 07:30 AM
