Results 1 to 15 of 22
Thread: Prop wrench?
    Apr 2017
    pa
    5 Post(s)
    Prop wrench?
    Any idea how to get this prop off? Special tool?
    Ft. Lauderdale, Fl
    Quote Originally Posted by bullet123 View Post
    That's a prop lock, takes a "key" socket that came with it. I have several keys at the shop for when one comes in with a lost key.
    dig around in the boat, maybe you will find it..... looks like this:
    Apr 2017
    pa
    5 Post(s)
    I dont have the boat. Just the lower
    Western Pennsylvania
    Maybe able to spin it with a sharp air chisel.
    90 21Skater w/300xs - sold
    98 STV Euroski w/280 - sold
  5. Thanks phillnjack thanked for this post
    Jul 2015
    northern lower michigan
    https://shop.mcgard.com/products/mar...5e26e44e0fa58b Give them a shout, maybe they can help you out.
  7. Likes Glasstream15 liked this post
    Ft. Lauderdale, Fl
    Quote Originally Posted by Euroski View Post
    Or wedge a chisel or something in between the sleeve and nut and use a wrench or channel locks to spin it out griping what you wedged in there
    Pekin, IL
    I have seen many locking lug nuts but that's my first locking prop nut. Good luck.
    Rock
    Team Junk
    Apr 2017
    pa
    5 Post(s)
    My first too. I could see protecting an expensive prop, but this is just an old aluminum junker.
    Jul 2015
    I have had a pair on my twins for 3 years now. They work very well. I keep the key like sockets zipped tied to the prop wrench. I got cards with #numbers on them so they can make new keys to match. There's only so many combs they make.. call them
    May 2016
    keys
    Can you cut a slot in it to turn it out like a flat head screw? Not sure how they work.
    Jul 2005
    AZ
    Quote Originally Posted by Whaaaaat View Post
    Same idea as wheel locks just a bit different..
    You can drill a few holes in the nut big enough for a nail..3 works well.. then should be able to grab them with channel locks still a pita but worked..
    Or take a small pipe drill a couple holes in the end put a nail thru and can use that to turn it
    '84 Checkmate Convincor
  14. #12
    Jul 2015
    No,the stainless collar spins on its own.
  15. Thanks Whaaaaat thanked for this post
  16. #13
    Apr 2017
    pa
    5 Post(s)
    Im probably just gonna cut prop apart.
  17. #14
    Apr 2017
    pa
    5 Post(s)
    Got it!!
  18. Likes jmatak9 liked this post
  19. #15
    Jul 2002
    FT WORTH, TEXAS
    AHHHHH necessity the mother of invention nice going Trent
  1. How long is a Merc floating prop wrench?
    By mariawhitetrash in forum Props, Setup, and Rigging
    Last Post: 01-19-2015, 09:16 PM
  2. i need a wrench
    By spooky in forum Technical Discussion
    Last Post: 05-08-2004, 08:10 PM
