Results 1 to 14 of 14
10-04-2019, 11:29 AM #16000 RPM
- Feb 2011
- HUDSON, FLORIDA
- 1,528
- 433
- 64
- 435
- 452
use of primer bulb on efi motor?i
is it common to use the primer bulb when cold starting an efi motor? i leave my key on for 5-6 seconds, assuming elect pump has pressurized lines then crank it. it does not start immediately. do you guys use the primer when u launch? i thought that was a carb thing. jsre said i need to prime first. motor should start immediatly. any comments 225 2.5.?? my yellow/red wire is connected to the solenoid lug
10-04-2019, 11:46 AM #2
my 300x i need to use the primer bulb if i have not ran the boat in a week or so. It fills the low pressure pump that then fills the EFI high pressure pump.
Just a little Cat.
24 Twister V8 E-Rude (For Sale)
2008 Concept Sport Deck 2x 300X
10-04-2019, 12:14 PM #3Team Member
- Sep 2008
- Dow, IL \ Theodosia Mo.
- 297
- 17
- 87
- 51
Promax with vst use primer bulb
Forkin' Crazy, tux974 liked this post
10-04-2019, 12:40 PM #4Screaming And Flying!
- 14,753
- 381
- 1305
- 5602
- 11033
Yep, 1st start of the day pump er up. Should be good rest of day. If not, check for air leaks in line. My stream with a very short fuel run stays tight for months. My other boats with a longer fuel line run need it every time 1st start. Due to expansion and contraction from temps?
10-04-2019, 01:10 PM #5
I use it to re-prime the line after I change the on board fuel filter on my Yamaha.
1993 Cougar 21ft MTR Superbender SHO
10-04-2019, 01:59 PM #65000 RPM
- Sep 2017
- ontario
- 717
- 68
- 43
- 73
- 171
If JSRE says do it - just do it . All i know he is all that when it comes to knowledge on these merc 2.5 .
10-04-2019, 02:24 PM #7
Prime it first start, if the VST is not full you will cook the fuel pump.
10-04-2019, 02:39 PM #86000 RPM
- Feb 2011
- HUDSON, FLORIDA
- 1,528
- 433
- 64
- 435
- 452
ILL try priming for cold starts, from now on. see if it kicks right off! thanks guys.. 4 stroke suzuki never need a prime btw.
10-05-2019, 03:10 PM #9
Could a primer bulb be put inside the boat off the fuel tank which is easy to get to?
10-05-2019, 07:12 PM #10Member
- Jul 2018
- Bonneau beach SC
- 52
- 15
Thats where mine is, with ports in vertical position discharge up. Clay
10-05-2019, 07:36 PM #11
Dave Strong, tux974 liked this post
10-05-2019, 07:45 PM #12
Forkin' Crazy liked this post
10-05-2019, 08:05 PM #13
Ran my 300XS for 10 years with a holley set to 4psi max just to supply engine.
90 21Skater w/300xs - sold
98 STV Euroski w/280 - sold
10-06-2019, 05:31 AM #14
Dave Strong liked this post
primer bulb not acting right
By 200VEGAS in forum Technical DiscussionReplies: 9Last Post: 09-12-2009, 10:50 AM -
Primer Bulb or no Primer Bulb???
By 55DONAHUE in forum Technical DiscussionReplies: 5Last Post: 06-12-2006, 04:38 PM -
primer bulb
By big poppa pump in forum Technical DiscussionReplies: 3Last Post: 09-15-2005, 03:06 PM -
Primer bulb or not.
By jrpromax in forum Technical DiscussionReplies: 3Last Post: 03-16-2002, 12:24 AM
