Results 1 to 3 of 3
    Oct 2019
    Lakefield ON
    Looking for a 150-200 Merc
    For my 18' Charger, 1986. 20" shaft please message me if you know of any options out there.
    Mar 2017
    Miami, FL
    I have a 150 that runs almost perfect. It is a 1988 with a 200 horizontal front half, and later model carbs off a 175. I think it is running a bit rich right now, I haven't had time to mess with it. It is a freshwater motor, I have been running it in the canals down here. 105-110 compression on all 6. 16 amp charging system. I can help with shipping if you don't find something local. Last motor I sold I sent to the Turks and Caicos. I'm looking to get $1200 for it
    I also have a 1995 200 Carb FF block. Drilled exhaust, carson reeds and stuffers, solid mounts, bobs tuner. 40 amp charging system. The motor is a saltwater motor but I recently bought a freshwater complete mid section from a member on here so there is absolutely no rust. I have put about 10 hours on it since the new mid and I also put new head gaskets at the time to see how the bores looked. Motor screams and pushes my heavy flats boat to 73 mph. Probably 75 if it wasn't 95 degrees out every day this summer.
    Oct 2019
    Lakefield ON
    Thanks man.
  1. Replies: 6
    Last Post: 07-14-2019, 11:48 AM
  2. merc water pressure gauge part# to match older merc gauges??
    By syclone01 in forum General Boating Discussion
    Last Post: 09-09-2016, 10:48 PM
  3. Lifeline jacket, merc manual, merc lifting ring, LU flush adapter
    By John S in forum Misc. Parts and Accessories
    Last Post: 07-13-2016, 02:21 PM
  4. Mercury Tech: 50hp 4cyl Merc vs. 70hp 3cyl Merc vs. ??? - Weight vs HP - Opinions??
    By Steve2ManyBoats in forum Technical Discussion
    Last Post: 02-22-2016, 07:25 AM
