Results 1 to 15 of 36
09-29-2019, 05:43 PM #1
1997 gl 150 rod gone through the front half
just putting this out there to see what you guys think about welding this up and also if you know if another front half could be used on this motor if the weld dont take ?
also what would cause this to happen. motor just supposedly been rebuilt lasted like just 30 seconds on the hose at just idle . not revved up at all . premix fuel , vro was disconnected .
thanks in advance guys.
09-29-2019, 07:26 PM #25000 RPM
- Jan 2008
- SUMMERVILLE S.C.
- 201
- 34
- 42
That can be welded up and be fine...or swap a different front half on..looks like a rod bolt came through..if that happened 30 seconds into the first crank up after a rebuild ,then maybe someone got a rod cap on backwards...or forgot to torque the rod bolts....
phillnjack, Ricky McAllister thanked for this post
09-30-2019, 03:38 PM #3Screaming And Flying!
- Jul 2002
- FT WORTH, TEXAS
- 8,031
- 9
- 146
- 313
- 503
x2 on the cap nobody can tell till you take it apart!!!!! look carefully at cap if still attached to see if it was backwards it only fits one way
09-30-2019, 11:01 PM #45000 RPM
- Jun 2009
- central minnesota
- 770
- 30
- 24
my guess---untourqued rod bolt,jmo, and 59years experance,-th
phillnjack thanked for this postphillnjack liked this post
10-01-2019, 08:57 AM #5
If the rod came loose the crank is junk. And you would have heard that when running. More the likely the piston seized and broke rod, in that case motor may be reusable. What pistons were used? Was the rod fixture used to assemble rods?
10-01-2019, 01:56 PM #6Screaming And Flying!
- Jul 2002
- FT WORTH, TEXAS
- 8,031
- 9
- 146
- 313
- 503
yes i see it thru the hole i was not thinking about what else could have caused it but the probability that piston stuck is more probable the the cap coming loose especially after rebuild when a piston sticks in a particular hole and alum is deposited on the sleeve walls it cannot be just bored out and re pistoned most of the time as aluminum on the sleeve causes the piston to push the wall of that cylinder outward and when it cools off a gap has been born between sleeve and sleeve holder creating a no heat transfer situation and same hole will stick again shortly i only learned thsi from jim ruck after he refused to just rebore a block i sent to him long years ago then confirmed by James perry after that!!!!! afterwards i no longer bored any cylinder that had stuck a piston and left metal on the sleeve i had a sleeve installed just my 02 thanks to performance marine he was thinking and i was not but when you get 74 its legal
nitro_rat, phillnjack thanked for this postphillnjack liked this post
10-01-2019, 02:30 PM #75000 RPM
- Jan 2008
- SUMMERVILLE S.C.
- 201
- 34
- 42
it was 30 seconds on a hose at idle ...don't thinks that would be a seized piston...
10-01-2019, 02:52 PM #8Screaming And Flying!
- Jul 2002
- FT WORTH, TEXAS
- 8,031
- 9
- 146
- 313
- 503
well if you heard no rod banging around then it still up for guess work!!! have you taken it apart it would solve all the what ifs???? it take me less then 30 minute to disassemble a entire powerhead
10-07-2019, 12:35 PM #9Member
- Oct 2019
- Clearwater, Fl.
- 61
- 10
Is the rod cap intact? If so a foreign object got between the rod and block. (Reed plate retainer screw / bolt.) If there's no other internal damage that hole looks like it could be welded.
phillnjack thanked for this postphillnjack, Ricky McAllister liked this post
10-13-2019, 10:17 AM #10
no the rod cap broke away but one of the rod bolts was still in the other half ..... the fella who's motor it is has just joined here today waiting to be full approved then he can give all the info on it.
10-13-2019, 10:24 AM #11
that was my first thought. not torqued up correctly
10-14-2019, 12:27 PM #12Junior Member
- Oct 2019
- Chelmsford
- 11
I'm the owner of the 97' faststrike 150. Bought the motor. Claimed to have had a $5000 repair job. It's like new condition. Mounted it on the boat, hook up electrical, over looked everything. Had it on muffs and premix. Initial start was real nice, 3, 4 turn overs a it fired and idled. No.more the 30 sec, I heard 2, 3 loud clicks in the engine, and immediately stalled. Its was locked up. Opened the heads, to find one piston not moving.
10-14-2019, 12:38 PM #13Junior Member
- Oct 2019
- Chelmsford
- 11
Pics
10-14-2019, 12:39 PM #14Junior Member
- Oct 2019
- Chelmsford
- 11
10-14-2019, 12:44 PM #15Junior Member
- Oct 2019
- Chelmsford
- 11
I have the crank case off now. Tomorrow I will have more pics. This is my first time having a power head opened up, and I feel like I have to inspect everything now. I will be replacing all 12 of the rod cap bolts. They both snapped at the heads. There is new rings on all pistons and one new sleeve.. see.. this is what I've found so far.. blown rod: stern side- center. New sleeve insert : starboard side - center. It looks to.me the sleeve in out in offset anout an 1/16", to an 1/8". Would this have cause such an immediate failure?
2.0 liter block, front half 2.5 200 ported like drag, big bearing efi front half
By superboattwin250 in forum Misc. Parts and AccessoriesReplies: 4Last Post: 04-26-2015, 03:43 PM
